JBSEM Tuning
Results 1 to 14 of 14
    Der_Techniker's Avatar
    Foursprung Duck Technique
    Oct 2010
    Coventry, West Midlands
    992
    Post Thanks / Like
    Headlamp washers
    Best way to transfer my washer jets over to a FG RS4 bumper? Dremel and epoxy, sikaflex etc???
    2000 Silver Audi A4 1.8T Sport, With added Carbon Goodness
    "Arguing with an engineer is a lot like wrestling in the mud with a pig. After a few hours, you realize that he likes it."
    Bradderz_1988's Avatar
    The only way is ..... German !
    Aug 2010
    Greater Manchester
    1,065
    Post Thanks / Like
    The headlight washer are mounted to the bumper crash bar iirc so you will just need to cut out the holes so that the washers sit flush with the bumper.
    1999 Audi A4 1.8T Quattro Sport - Volcano Black - Frankenturbo'd
    Wanted - S4 Skirt/Wing trims, S4 side skirt brackets.
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,274
    Post Thanks / Like
    Blog Entries
    I think Foxmeister has alot of images in his build thread about it.
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,611
    Post Thanks / Like
    Yep, both Bradderz and Scott speak the truth!
    I was looking into doing it with my RS4 Rep bumper until an oem unit became available and i went that route! The concept is, for all washers other than oem RS4, the washers unit/caps are pushed up with the pressure and then rest back on the bumper itself, so in reality you only need a hole big enough for the washer jet to get thru, but less than the width and breadth of the cap so the bumper still supports it when retracted!
    I still have my original Sport bumper here with the holes, i can measure sizes if you need it but im sure it'll be obvious when you start doing it!
    Project RS28 build
    "Stick a V8 in it!"
    Cleveleys, Lancashire
    11,840
    Post Thanks / Like
    Facelift A4's are like the RS, ie the washers are recessed into the bumper.
    For Sale: Breaking B5 A4 - Check my eBay page!
    Wanted: Facelift A4 Front Bumper with Headlight Washers.
    2000 A4 1.8T Sport Quattro Avant, Beere Pearl, TT Carriers and B6 312mm Disks.
    2000 A4 1.8T Sport Quattro Saloon, Black-ish, Now Running!
    1997 S4 - PPC £999 Challenge Track Car Build starting soon!
    Audi V8 powered Land Rover Defender build in progress.
    Oct 2010
    992
    Post Thanks / Like
    well i can either:
    • Use PFL wash jets and get colour matched.
    • use surface mounted ones (like these: Wash Jets)
    thoughts? as i think FL ones will be tricky to make them fit correctly.
    Oct 2010
    992
    Post Thanks / Like
    Could use some from a 2003> laguna and just paint to match the front bumper?
    Oct 2010
    992
    Post Thanks / Like
    What would be the tidiest/easiest route in your opinion guys?
    PFL ones or use some like the mk2 laguna where they are always visible on the bumper?
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,274
    Post Thanks / Like
    Blog Entries
    PFL flush units.
    Look so much better.
    Don't they sit or clip on top of the jets?
    Oct 2010
    992
    Post Thanks / Like
    think the cover clips to the top of the jet head.
    Now to find someone who is breaking a PFL and will part the jets and pipework out of the bumper.... hmm
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,274
    Post Thanks / Like
    Blog Entries
    I can't remember if its the PFL or FL that has the flush units. But they are deffo the best.
    Any of the breakers what you after?
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,274
    Post Thanks / Like
    Blog Entries
    I had a thought.
    No idea if it will work.
    But if you're after a flush subtle look.Check out BMW's rear washer jet for the their E34 tourers.
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,611
    Post Thanks / Like
    Quote Originally Posted by ScottB5 View Post
    I had a thought.
    Explain Scott....with pics for simple c*£ts like me!
    Project RS28 build
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,274
    Post Thanks / Like
    Blog Entries
    Quote Originally Posted by Foxmeister View Post
    You'd only forget.
    Ok then.
    The ones in the tail gate are small round flush fit the eject up to squirt. Same out head light washers but they are smaller and flush fit.
    I'm not fully 100% sure how they work, attach or their size. This all from memory of when I had mine and I never worked.
    I'll find more info and pictures tomorrow for you.
  1. Headlamp washers
    By ru4shaw in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th July 2010, 01:49
  2. Headlamp Washers.
    By Don76 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th March 2009, 18:17
  3. Headlamp Washers
    By c16wko in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2008, 08:57
  4. Headlamp washers
    By Audi_TT 83 in forum TT/TT-S/TT-RS Forum
    Last Post: 12th February 2008, 21:28
  5. Headlamp Washers
    By ZAF in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th October 2003, 11:13
