AWEsome GTIDTUK
Thread: Frosen lock
    a4-er's Avatar
    Feb 2012
    17
    Post Thanks / Like
    Frosen lock
    This morning the door to my car wouldent open from outside.. Just from inside. Couldent feel the lock like when you open the door. I washed my car. And the day after i couldent open it. Its pretty cold here now. I just wondered if it could be the cold. Or is the lock broken?
    Bradderz_1988's Avatar
    The only way is ..... German !
    Aug 2010
    Greater Manchester
    1,065
    Post Thanks / Like
    Had same problem twice in a week don't think theres a leak on the system as the pump operates for 2-3 seconds do just presume its this ****e weather lol
    1999 Audi A4 1.8T Quattro Sport - Volcano Black - Frankenturbo'd
    Wanted - S4 Skirt/Wing trims, S4 side skirt brackets.
    B5QUAT's Avatar
    Apr 2011
    Manchester
    206
    Post Thanks / Like
    Yeah same here. Try blasting a load of WD40 into the catch mechanism on the side of the door. I did that and it's not done it since.
    Ming Blue 1999 1.8TQS. Mods so far: full non res Milltek, decat pipe, Weitec Ultra GT suspension, Meyle front arm kit, 18" BBS LM reps, interior LED upgrade, Advanced tuning chip (20psi), Pipercross filter. Planned mods: FMIC, B6 S4 brake setup, RS4 Clutch, ECS flywheel, GT28RS conversion and custom remap.
    a4-er's Avatar
    Feb 2012
    17
    Post Thanks / Like
    Yeah. Guess i will have to try that.
  1. steering....lock to lock
    By shamrock in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th July 2010, 16:24
  2. cg lock £15 off
    By voorhees in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2009, 13:23
  3. De-lock
    By disley in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st May 2008, 16:23
  4. What lube/grease to use on hinges/lock latches/lock strikers?
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th February 2006, 14:54
  5. A6 Lock Out!!
    By Towerman in forum Detailing
    Last Post: 15th October 2004, 16:37
