GNJDPM
    audi-a6's Avatar
    Aug 2011
    christchurch
    174
    Post Thanks / Like
    Boost gauge, where to plumb in?
    on the 2.7t, is it okay to feed a boost gauge off the vacume pipe that goes to the fuel pressure regulator? or will that be an incorrect reading?
    Bradderz_1988's Avatar
    The only way is ..... German !
    Aug 2010
    Greater Manchester
    1,065
    Post Thanks / Like
    Mine is hooked up to the FPR and reads fine so I'm guessing it would be the same for the 2.7T.
    1999 Audi A4 1.8T Quattro Sport - Volcano Black - Frankenturbo'd
    Wanted - S4 Skirt/Wing trims, S4 side skirt brackets.
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    155
    Post Thanks / Like
    Yes, it should be tee'd into the FPR vac line.
    Der_Techniker's Avatar
    Foursprung Duck Technique
    Oct 2010
    Coventry, West Midlands
    992
    Post Thanks / Like
    as above, thats where mine is
    2000 Silver Audi A4 1.8T Sport, With added Carbon Goodness
    "Arguing with an engineer is a lot like wrestling in the mud with a pig. After a few hours, you realize that he likes it."
    audi-a6's Avatar
    Aug 2011
    christchurch
    174
    Post Thanks / Like
    cool, thanks peeps
  1. Boost leak, Weak Actuator or boost gauge?
    By DaveA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2011, 13:51
  2. Replies: 0
    Last Post: 17th January 2011, 21:00
  3. Where to Plumb in your boost gauge...
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th February 2010, 22:48
  4. Boost gauge only reads negative boost?
    By garyrmills in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th October 2009, 21:45
  5. where to plumb in boost gauge?
    By Starry in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd June 2007, 10:40
