JuicyDTUK
Results 1 to 9 of 9
    jonnycraig's Avatar
    Jun 2009
    Port Talbot
    147
    Post Thanks / Like
    Anyone know of any cheap Audi Breakers / garage in the Swansea/Port Talbot Area?
    My B5 probs are ongoing, usual thing cash is a very tight and things then gather up and fail all at once! I need my car to travel the 70 mile round trip to work every day. So any suggestions on the best way or order to get the following fixed, or do I put the money into a cheap runner with the risk of inheriting new probs.
    1. Last night ice has burst the radiator, hole must be too big for radweld to fix (not that I hold much hope in it anyway) thought I had enough antifreeze in there but obviously not!
    2. There is a water leak where coolant pipe comes from the top of the rad and enters the block between the injectors, gasket gone?
    3. Indicators do hazard lights up or down - Stalk or hazard switch
    4. Fanbelt is starting to fray so should I do timing belt, waterpump and thermostat too?
    5. 152000 miles on the clock, so timing belt due soon anyway? 160k is it?
    6. Oil temperature gage has never shown a reading is that dangerous?
    7. and finally.... water temperature usually displays about 60-70 degrees according to the gage and climate code 51 display trick (lazy/faulty thermostat?)
    Thanks for reading my probs
    Cheers Jonny
    1996 A4 B5
    1.9TDI SE
    Gone but not forgotten
    Audi A4 2.5TDI Quattro
    Skoda Octavia 1.9SDI (Wont be missed lol)
    audiv6quattro's Avatar
    Dec 2010
    East sussex
    388
    Post Thanks / Like
    Hi mate, to be honest if apart from the faults you've mentioned and if the head gasket hasn't gone it's probably worth fixing, because as you say you will only end up buying a cheap run-around and inherit more problems. All the things you've listed shouldn't really come up to more than a couple of hundred quid and where are you going to get a decent car for that?? Entirely your choice but I would fix it if I was you. If the head gasket hasn't gone anyway.
    1996 A4 2.6 v6 quattro,love the car hate the cost!!
  4. Thanks jonnycraig thanked for this post
  5. #3
    Dec 2010
    East sussex
    388
    Post Thanks / Like
    They do have a couple of rads on eBay for £30 not to sure if it makes a difference if you cars auto or not though audi a4 1.9 tdi radiator | eBay
  6. Thanks jonnycraig thanked for this post
  7. #4
    Alsie's Avatar
    Sep 2011
    133
    Post Thanks / Like
    I'm breaking a B5 at the moment, in the south Wales area, if you need parts cheap, I'm your man lol!
    1998 A4 Estate 1.8 Turbo Sport in Imola Yellow
    1998 A4 Estate 1.9 TD in Paradise Green (Broken sob)
    2004 Subaru Impreza WRX STi Type Uk PPP (The Doctor replica)
    1994 Honda CBR900RRR Urban Tiger Fireblade.
  8. Thanks jonnycraig thanked for this post
    Likes ScottB5 liked this post
  9. #5
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,274
    Post Thanks / Like
    Blog Entries
    1. Quote Originally Posted by jonnycraig View Post
      Did you put radweld in to your rad? If not, please don't. But a new rad off ebay or if money is a bit tight, talk to a couple of the B5 lads thats breaking their motor.
    2. Quote Originally Posted by jonnycraig View Post
      Thats possible the same thing as I just sold. Its plastic flange that splits. its bout £10-£15 off ebay or again, talk to one of the breakers and see they can supply you with the one off of theirs as a temp fix but I would deffo look in to a new one.
    3. Quote Originally Posted by jonnycraig View Post
      They do what up and down? You indicate left and all indicator fault? Possible relay fault. Again Talk to a breakers and ask for the Hazard switch.
    4. Quote Originally Posted by jonnycraig View Post
    5. Quote Originally Posted by jonnycraig View Post
      I'll answer 4 and 5 here. Yes do it. Fan belt is every 60k or 4 years (I think) but its at 152k and no sign of replacement then do the two belts, waterpump, thermo and adjusters.
    6. Quote Originally Posted by jonnycraig View Post
      Not really. Most cars don't have a oil temp.
    7. Quote Originally Posted by jonnycraig View Post
      Could be thermo. get that replaced but if you order the part for fault #2, ask them to keep the coolant sensor in.
  10. Thanks jonnycraig thanked for this post
    Likes jonnycraig, Alsie liked this post
  11. #6
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    Bridgend, South Wales
    507
    Post Thanks / Like
    To get the real-time coolant temp it is code 49 on the climate control panel!
    I replaced my thermostat the other day as I was also getting a low gauge temp (it has always sat bang on 90 degrees once warmed up) and this cured it totally.
    A Genuine Audi 'stat cost less than 20 quid , so don't try and get a cheaper/pattern one, by all accounts they are crap!
    Having said that, the thermostat I took out was also Genuine , and had 'only' lasted since Feb '09 and approx 40k miles!
    '99 Ming Blue A4 Avant TDi SE 110 + Dragon Performance Tuning Box
    Factory sunroof / Aircon+Climate /Royale blue leather
    '72 1302LS Karmann Beetle Cabrio Silbermetallic
    '63 Karmann Ghia Sunroof Coupe Pacific Blue
  12. Thanks jonnycraig thanked for this post
  13. #7
    jonnycraig's Avatar
    Jun 2009
    Port Talbot
    147
    Post Thanks / Like
    Cheers for all the replies and advice guys, to top things off my battery died this morning and with no neighbours around to jump start me I had to ring the AA Grrr!!
    Quote Originally Posted by Alsie View Post
    Where abouts are you? PM me if you wanna give a bit more detail about what you have etc
    1996 A4 B5
    1.9TDI SE
  14. #8
    Alsie's Avatar
    Sep 2011
    133
    Post Thanks / Like
    Pm sent
  15. Thanks jonnycraig thanked for this post
  16. #9
    jonnycraig's Avatar
    Jun 2009
    Port Talbot
    147
    Post Thanks / Like
    Pm sent
    Cheers dude will get back to you later when I home from work.
    1996 A4 B5
    1.9TDI SE
  1. Best garage for Audi servicing in the Portsmouth area
    By polar in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th January 2010, 18:25
  2. Audi breakers in essex area?
    By BONEHEAD_TDI in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th June 2008, 16:55
  3. Anyone know any decent builders in the swansea area?
    By SonicDeathmonkey in forum General Chat
    Last Post: 28th October 2007, 18:06
  4. Audi Breakers Birm cov area?
    By Ilogik in forum General Chat
    Last Post: 28th April 2005, 13:22
  5. Audi breakers/salvage Derby/Burton area?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2004, 08:26
