JBSRevo Technik
Results 1 to 9 of 9
    May 2011
    Post Thanks / Like
    98 2.5 tdi a4 - no boost from the turbo help
    as above really the car is really slow and struggles to rev above 3000 rpm, no turbo kick.
    Starts fine/ no smoke/ doesnt use oil turbo shaft has very little play and spins free.
    Put a boost gauge on it today (plumbed into the feed to the boost soleniod) and it only shows a vacumn when driving.
    Can anyone point me in the right direction - i suspect the wastegate flap is stuck open?? I'm more use to petrol turbo cars than diesel.
    Jan 2011
    northants
    84
    Post Thanks / Like
    get diag test done and post results
    diffas's Avatar
    Lahti, Finland
    93
    Post Thanks / Like
    Sounds like wasted MAF.
    Slow and smoking - A4 2.5TDi+ 204kw/570nm
    Jan 2011
    Aberdeenshire
    207
    Post Thanks / Like
    Try to move the actuator by hand, the turbos' variable vanes often soot up and stick.. If it doesn't move up and down, search this forum for the Mr Muscle clean thread to fix it.
    If you have access to VCDS, check for over-boost codes, and try the actuator vacuum test.
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    May 2011
    Post Thanks / Like
    The wastegate arms moves up and down ok - this can been seen when I start and stop the engine, I have run the car with the Maf dissconnected and it does seem too be a bit better slightly more power and reving to 4000 rpm easier.
    I take it having the MAF disconnected puts the ECU in a reduced performance mode
    Banned
    Aug 2010
    1,043
    Post Thanks / Like
    Quote Originally Posted by turbozx View Post
    yes and no.
    with the airmass meter plugged in the ecu will read it and fuel accordingly. even if the airmass is faulty and reading half the amount of air that is actually going in.
    basically at idle theres say 200grammes per second of air. full boost theres 1200 grammes per second.
    you unplug the airmass, the ecu sees its open circuit and subtitutes the actual value produced by the airmass (which isnt there anymore) with a set figure of 550 grammes per second. a medium value.
    you getting the idea?
    to improve by unplugging it it must be reading less than 550 when it should be reading 1200.
    you really need to get it on the diagnostics to do a running actuator test of the boost control system. as you can run this test independant of airmass fault limitations.
    basically you set the test in motion on the diagnostics and the ecu increases the idle speed to 1300 rpm. it then switches the boost control soleniod from 0% to 100% and back every 5 seconds. this works the variable vane in its full plane of motion. on the diagnostic it displays the signal from the boost pressure sensor. if all this looks ok. you can rule out any boost control faults in about 2 minutes without even opening the bonnet!
    you can do exactly the same sort of test with the egr, rotary pump advance retard. etc.
    the only thing left is the airmass.......
    May 2011
    Post Thanks / Like
    I only have basic vagcom fault codes were as followed
    00550
    00523
    00553 bear in mind i had disconnected the maf before hand
    I cleared the fault codes went for a drive and scanned again with no codes
    I measured block 003 MAF specified vs actual and the actual never went over 600 when specified was 900,
    Banned
    Aug 2010
    1,043
    Post Thanks / Like
    hmmm, id be buying an airmass meter then.
    May 2011
    Post Thanks / Like
    changed the MAF for a new Bosch one - made a slight improvement.
    How do you plumb in a boost gauge on these cars?
  1. more boost from turbo??
    By A3tell in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2011, 21:03
  2. Replies: 26
    Last Post: 2nd March 2011, 14:15
  3. Turbo/boost controller
    By Swornd in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th November 2009, 22:12
  4. Turbo boost
    By G"MAN in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd October 2009, 08:39
  5. turbo boost?
    By edwin98 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th July 2003, 14:06
