Royh1179
hello guys im back again lol right i got the new stat, first of all i did the whole checking stat open with hot water in a pan ect all good did it 3 times closed to fully open so stats ok ,, removed old one and fitted new, bled system the best i could after flushing, using bleed tap on bottom of rad and bleed hole on heater hose left expansion cap off, , car got up to just under 90 and stays there,, heaters LUVLY and hot now iv got water circulation through lil hose on top of expansion bottle top hose hot bottom hose COLD!!!!! left it ticking over for ages temp stayed at jus under 90 heaters stay hot but yet bottom hose cold, gave it a drivre around block still same so whent donw duel carrige to next junction and back,,, temp still jus under 90 top hose hot bottom cold heaters boiling ????? i know the water is cooled as it flows thru rad but that bottom hose should still get warm surley ?????
