UnicornDTUK
    Royh1179's Avatar
    Jan 2012
    lincolnshire
    33
    Post Thanks / Like
    BOTTOM HOSE COLD !!!
    hello guys im back again lol right i got the new stat, first of all i did the whole checking stat open with hot water in a pan ect all good did it 3 times closed to fully open so stats ok ,, removed old one and fitted new, bled system the best i could after flushing, using bleed tap on bottom of rad and bleed hole on heater hose left expansion cap off, , car got up to just under 90 and stays there,, heaters LUVLY and hot now :-) iv got water circulation through lil hose on top of expansion bottle top hose hot bottom hose COLD!!!!! left it ticking over for ages temp stayed at jus under 90 heaters stay hot but yet bottom hose cold, gave it a drivre around block still same so whent donw duel carrige to next junction and back,,, temp still jus under 90 top hose hot bottom cold heaters boiling ????? i know the water is cooled as it flows thru rad but that bottom hose should still get warm surley ?????
    "Stick a V8 in it!"
    Cleveleys, Lancashire
    11,839
    Post Thanks / Like
    It will eventually, but its sort of normal to stay cold on shorter journeys. The stat stays closed until the engine gets to 90c, then it opens a small amount and starts bleeding water thru. The water in the rad is so cold that it will typically only let by at a very slow rate, and thus take a long time to get to the point that its heated the entire radiator up.
    If you have climate control you can view the engine coolant temp on there, so long as its sitting at a sensible temperature it'll be fine.
    For Sale: Breaking B5 A4 - Check my eBay page!
    Wanted: Facelift A4 Front Bumper with Headlight Washers.
    2000 A4 1.8T Sport Quattro Avant, Beere Pearl, TT Carriers and B6 312mm Disks.
    2000 A4 1.8T Sport Quattro Saloon, Black-ish, Now Running!
    1997 S4 - PPC £999 Challenge Track Car Build starting soon!
    Audi V8 powered Land Rover Defender build in progress.
    Royh1179's Avatar
    Jan 2012
    lincolnshire
    33
    Post Thanks / Like
    yeah it stays just under 90 if im ticking over or driving heater is now boiling hot no HOT smell from engine oil temp is good just making sure really as i got a 600 mile round trip coming up and bont want to boil it
    thanks
  1. Replies: 18
    Last Post: 1st December 2008, 13:30
  2. bottom hose
    By Jules in forum General Chat
    Last Post: 5th June 2007, 11:01
  3. bottom hose
    By Jules in forum Diesel forum
    Last Post: 9th May 2007, 00:43
  4. bottom hose
    By Jules in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th May 2007, 00:40
  5. s3 Bottom intercooler hose
    By S3_Shaun84 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd October 2005, 14:50
