Backdraft MotorsportJuicy
    audiv6quattro's Avatar
    Dec 2010
    East sussex
    388
    Post Thanks / Like
    Another steering problem
    Hi in December 2010 I had a problem with my power steering pump so replaced it with a new one. Now the other day I was driving round a roundabout and steering went really stiff (scared me a bit) and the pump started making a really loud sort of grinding noise, getting louder when I turned the wheel either way, the haven't driven the car since, noise is still there but when I leave the car running for a while the power steering fluid overflows through the cap and is like a yellow kind of colour, the noise is definatly coming from the pump there's no mistaking that but do you think there could be a blockage somewhere along the line or could be something to do with the steering rack?? I took the pump apart last night and it's not running dry at all there was plenty of fluid in the pump. Please help it's driving me mad. Cheers
    1996 A4 2.6 v6 quattro,love the car hate the cost!!
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,274
    Post Thanks / Like
    Blog Entries
    I've never delt with power steering or pumps.
    apart from removing from cars.
    I don't even know if this is possible but can you take a pipe off one side of the pump or rack and see if fluid it passing through?
    If the fluid is over flowing after a few mins suggests to me that the pump is working but its just pumping fluid back on its self and causing the bot to over flow or the fluid is not going in to the rack so causing the over flow, taking fluid out of the rack but not back in.
    Dec 2010
    East sussex
    388
    Post Thanks / Like
    Cheers Scott, when I put it all back together I had exactly your thought in mind I didn't connect the pipe that leads to the rack and turned the pulley by hand (as if to prime it) and fluid flowed through the pump but didn't overflow if that makes sense, it flowed enough to just about see the fluid in the hole where the fluid comes out but no higher. If it was something to do with the rack would all the noise be coming from the pump still or would the rack itself be making a noise aswell, thanks again scott
    "Stick a V8 in it!"
    Cleveleys, Lancashire
    11,839
    Post Thanks / Like
    If it were a blockage the pump would probably be operating against its pressure relief valve, which may well make a racket. It will also cause the fluid to get very hot, which in turn will cause it to boil, which is probably why you were seeing it coming out of the cap.
    For Sale: Breaking B5 A4 - Check my eBay page!
    Wanted: Facelift A4 Front Bumper with Headlight Washers.
    2000 A4 1.8T Sport Quattro Avant, Beere Pearl, TT Carriers and B6 312mm Disks.
    2000 A4 1.8T Sport Quattro Saloon, Black-ish, Now Running!
    1997 S4 - PPC £999 Challenge Track Car Build starting soon!
    Audi V8 powered Land Rover Defender build in progress.
    Dec 2010
    East sussex
    388
    Post Thanks / Like
    Cheers aragorn right when it stops snowing (bloody snow) I'm shooting outside to take all pipes of on clean them up check for blockages ect hopefully this will be the case as I can do without the expense of a new pump/rack ect
  1. Steering problem Help
    By beezajoe in forum Handling
    Last Post: 18th February 2011, 20:42
  2. Steering problem??
    By A3Bash in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th July 2010, 21:33
  3. steering problem
    By vw754 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st February 2008, 15:16
  4. steering problem
    By vw754 in forum Handling
    Last Post: 31st January 2008, 22:42
  5. A4 Tdi, engine problem AND steering problem! PLEASE help!!
    By mattsavage in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th February 2007, 16:02
