Page 2 of 2 FirstFirst 12
Results 41 to 45 of 45
Like Tree1Likes
Thread: Have a slight problem....
  1. #41
    May 2010
    Bedford
    2,877
    Just get some 225 tyres and lower it a bit, the camber increase will pull the top of the wheel in and sit within the arch. Even my 7.5j 17s were flush to the front until i lowered it and now they`re about an inch in from the lip. Even since raising it about 20mm they`re still in the arches.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
  3. #42
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,375
    Thats not flush though, its sticking out around an inch :P
    Its already on fairly narrow tyres too for such a wide rim, 225's arent going to help much.
    Your wheels are 7.5" wide and probably ET45ish. His are ET24 and 8.5", so they're sticking out nearly an inch and a half more than yours.
    TD5 Land Rover Defender build
  4. #43
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    This has the classic ingredients of a great project waiting to evolve........
    Fit these Mazda Mx5 / Eunos Wide arch / flares / extensions | eBay
    Then smooth over the rivet sections for a sleek look!
    Project RS28 build
  5. #44
    Sam
    Oct 2011
    Bomber County
    37
    Right, so the overhang appears to be around 25mm max. I have spoken to a few people who have said lowering a car usually drags the wheel in a little. Does anyone know how much a 50mm drop will drag in the wheel? If its only 10mm that would mean running a stretched tyre in combo should make me legal as it will only require 20mm reduction in width. Sorry to drag this up again but I want these wheels on :-D
  6. #45
    "Stick a V8 in it!"
    15,375
    Camber change on the B5 isnt that large when lowering.
    8.5" rims at ET35 will go on with a 225 tyre and some arch trimming. Yours are ET24, so are 11mm further out than that.
  1. slight problem with my new 1.8t a4
    By p771 apm in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th June 2010, 08:22
  2. slight oil problem
    By kevsn in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th August 2008, 19:19
  3. New Member, Slight problem
    By TopT in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th September 2007, 11:47
  4. Slight problem
    By S4_SAT in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th August 2007, 08:03
  5. A slight problem!
    By k17rpo in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th December 2006, 19:28
