DPMRevo Technik
Results 1 to 18 of 18
    Feb 2009
    208
    Post Thanks / Like
    1.9 tdi afn hard starting (fixed maybe?)
    Today my car became a pita after running sweet for the last year. Car always used to start as soon as the key was turned, now its taking at least 10 secs of charging before it chunters into life....
    Car:
    1.9 tdi audi a4 avant estate
    218k miles on the clock
    Symptoms other than mentioned above - none. Car runs sweet when going with mpg, sounds and temps all normal.
    Temps are hovering around 0 today so my money is on a glow plug related issue. Going to look in the morning and see what i can see. Would an engine that is up to temp restart as soon as it was switched off because of residual heat in the cylinders? Mine doesn't, it seems starting it hard regardless.
    Any tips on what to look for with the glow plug system - any fuses, relays or sensors that i should check? I'll plug into vcds first thing and see if i get any clues there first.
    If it does turn out to be glow plugs i'd be tempted to go to halfords as they are open on sundays. Has anyone got experience of halfords glow plugs?
    Thanks in advance
    Jul 2007
    London
    1,571
    Post Thanks / Like
    i would say it's timing related as a retarded/advanced pump will only show in very cold weather. If the engine has good compression then it will start even in colder weather. Did you change the fuel filter re3cently or disturbed the fuel system in any way ? If you have vcds you could check the timing in basic settings block 0 with the tdi timing plugin. Glow plugs can be at fault but a healthy VE engine will start without glow plugs even in colder weather- will splutter and smoke for a while but it should still start. I would check the woddruff key on the end of the crank, it has a habbit of breaking which trows the timing all over the place and it will lead to bent valves if left unchecked ! If the timing is fine then i would change the glowplugs- use plenty penetrating fluid and make sure the engine is warm when on removal so you don't snap any ! Also a duff coolant temp. sensor can throw the timing out of the window, is your glow plug light stays on for longer than 10 sec ?
    FOR SALE:
    Feb 2009
    208
    Post Thanks / Like
    Nothing has been changed on the engine timing wise so the only thing that would throw the timing out would be if the woodruf key has snapped or if the belt has somehow jumped a tooth if I understand correctly.....
    Tried to run vcds last night but my laptop is so rubbish it's somehow lost all it's port settings.
    Hopefully will get vcds sorted then check all timing and electrical systems today
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,274
    Post Thanks / Like
    Blog Entries
    Good luck.
    Having the same engine thats fast approaching that mileage, I'd be interested in the fix.
    Just in case. :D
    When was the glow plugs changed last?
    Feb 2009
    208
    Post Thanks / Like
    right, some progress. Managed to get VCDS running and scanned the engine for faults, all that came back was glow plug relay - open or short to ground (didnt copy the code as i'm an idiot). I cleared the code and the hard start was still there but it fired up within 5 secs, the engine did feel a bit lumpy around 1500 rpm though.
    Next i decided to hit the glow plugs with some wd40 in preperation for taking them out. I started from the front, removed plug - liberal spray of wd40 replace plug. The next 3 plugs were snapped around the electrode! Looks like the plastic has become brittle with age, i sprayed them with wd40 and put them back as well fitting as they could be. To my surprise the engine fired up on the first crank and the next 3 times it did the same.
    I will need to get fuel today so will fill the tank, then drain the water off the fuel filter cause i dont think ive ever done that. Hopefully that was an easy fix for me, but i've now got a niggling doubt about this woodruff key. Can anyone telll me if you can check the tdi timing graph with vcds light as thats the only one i have.
    For reference the glow plugs have not been changed in the 50k miles i've owned the car.
  7. Likes ScottB5 liked this post
  8. #6
    Feb 2009
    208
    Post Thanks / Like
    left the car for a few hours before going out and cracking open the drain tap on the fuel filter. Car started on the button again - so hopefully that was a quick fix.
    i will see how it goes this week.
  9. #7
    Banned
    437
    Post Thanks / Like
    If you're going to get a new set of glowplugs then you can save on the dealer's prices by buying Beru ones as they make them for Audi, or at least do for the ASV TDI. GSF do them for a really good price on ebay.
  10. #8
    Feb 2009
    208
    Post Thanks / Like
    not sure if i need them as the problem seems to harness related, a quick look on vagcat doesnt seem to show the harness avaiable seperately. Does anyone know if you can but this on its ownb
  11. #9
    Feb 2009
    208
    Post Thanks / Like
    car started and run fine today whith no falut codes thrown over 120 miles. got a set of glow plugs today from halfords for £40 and fitted tonight. The harness is available for £800 plus vat from audi which i think i'll give a miss to.
    I will try to get one of the updated ones off ebay cause the connections are rubbish and there is no way to keep the connectors on the plugs.
    Ordered a relay 109 too so i'll try to replace that when it comes tomorrow.
  12. #10
    Alsie's Avatar
    Sep 2011
    133
    Post Thanks / Like
    £800???? Im breaking a 1998 1.9TDi avant soon, you will be more than welcome to the harness
    1998 A4 Estate 1.8 Turbo Sport in Imola Yellow
    1998 A4 Estate 1.9 TD in Paradise Green (Broken sob)
    2004 Subaru Impreza WRX STi Type Uk PPP (The Doctor replica)
    1994 Honda CBR900RRR Urban Tiger Fireblade.
  13. #11
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,274
    Post Thanks / Like
    Blog Entries
    Quote Originally Posted by Alsie View Post
    Load cover?!?!?!?!?
  14. #12
    Alsie's Avatar
    Sep 2011
    133
    Post Thanks / Like
    yes it has a load cover not the best condition though, needs cleaning
  15. Likes ScottB5 liked this post
  16. #13
    Feb 2009
    208
    Post Thanks / Like
    will take the rear wiper motor if its working....
    right - been thinking a bit more about the harness. The loom audi sell is the full engine loom which is obviously out of the question. I basically have 2 choices - i can either but a 2 cable loom from ebay which i will nbeed to splice into my existing harness:
    Glow plug wiring loom VW Audi Skoda Seat 1.9 various 028971766 New genuine part | eBay
    or i could save some loot and adapt the harness i have currently....
    The top of the glow plug is threaded so im thinking about cutting off the existing connectors, soldering and shrink wrapping on a few cm's of suitable wire with a ring connection and bolting it to the top of the glow plug. Other than being slower to remove the glow plug connections from the plugs can you see why there would any issue with this working?
    Even with the sub zero temps the car has started instantly for the last 2 days, so it looks like it was a combination of old plugs and dodgy connections causing the issues.
  17. #14
    Alsie's Avatar
    Sep 2011
    133
    Post Thanks / Like
    It wasa bit stop start lol... Seriously though the harness is foc if you need it
  18. #15
    Feb 2009
    208
    Post Thanks / Like
    A bit more thought before I go cutting the loom, would the wires that connect to the glow plugs have 1 strand or 2 strands I.e. I would not be able to connect a ring connector to it. ~ does anyone know?
  19. #16
    Biodiesel Purrrr
    Jun 2011
    London
    81
    Post Thanks / Like
    AFAIK is just the positive in the plug and earthed to the engine block -
    checked mine th other day with multimeter and was getting just under 12v at the plugs [unplug temp sender to get more GP time]
    one of my plastic sockets is broken in two like yours but still connects fine
    got myself a set of new Beru GPs to fit later... wish me luck!
    P)
    TDi Biodiesel sippin' A4 Avant - EGR blanked
    "Cars are good but Jeremy Clarkson is a dick."
  20. #17
    Feb 2009
    208
    Post Thanks / Like
    Good luck with the gp change.
    Car has been starting instantly this week even with the -5 temps weve been seeing so I guess my old gp's were probably past it anyway.
  21. #18
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    Bridgend, South Wales
    507
    Post Thanks / Like
    I replaced my glowplugs about a month ago as I'd realised that in the 90k miles I've had the car for I'd never even checked them!
    The car hadn't become difficult to start or anything.
    I too bought the Beru plugs via GSF off Ebay and apart from squirting some penetrant around the plug holes a few days before doing the job it was straightforward.
    All the plugs came easily and the whole job only took 20 mins to do (I did have to buy a thinwalled extra-long reach socket though), so don't let all the horror stories about glowplug removal on the internet put you off!
    Oh, and in the recent sub-zero temps it's started easier and more smoothly than it ever has.
    '99 Ming Blue A4 Avant TDi SE 110 + Dragon Performance Tuning Box
    Factory sunroof / Aircon+Climate /Royale blue leather
    '72 1302LS Karmann Beetle Cabrio Silbermetallic
    '63 Karmann Ghia Sunroof Coupe Pacific Blue
  1. A4 Tdi AFN starting issues...
    By Final 3Green Land in forum Diesel forum
    Last Post: 1st September 2011, 17:05
  2. AFN TDi
    By stoop44rio in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd February 2011, 22:12
  3. Hard starting
    By arthurfuxake in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd September 2010, 20:11
  4. 1.9 tdi hard starting warm with smoke
    By peterjumps in forum Classic Audi Forum
    Last Post: 26th October 2009, 08:09
  5. a4 tdi 99 afn
    By t2myd in forum Diesel forum
    Last Post: 20th March 2009, 18:49
