KowalskiAMD Technik
Results 1 to 10 of 10
    Royh1179's Avatar
    Jan 2012
    lincolnshire
    33
    Post Thanks / Like
    B5 1.8T THERMOSTAT ?!?!?!?!!??!!?!?
    hi all need to replace my stat has it seems to have jammed open as car stays way to cool,,, temp comes up when ticking over for a while and heaters blow warm but soon as i drive it cools back down,,,, so i guess its stat,, going to change it tommorow just seeking advice no fitting have been told i need to remove alternator ?? is this true or can i get to it from underneath as it looks like i can ??? whos done it and best way of getting it done ,,,,, thanks guys
    Byzan Pics's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    10,704
    Post Thanks / Like
    Easy from underneath, either fiddle the 2 x 10mm bolts out around the support bracket, or add a 13mm nut to the removal for better access.
    The worst bit is the coolant running dowen your arm
    Royh1179's Avatar
    Jan 2012
    lincolnshire
    33
    Post Thanks / Like
    thanks mate and yeah water down the arms this time of year isnt going to be enjoyed lol
    Bradderz_1988's Avatar
    The only way is ..... German !
    Aug 2010
    Greater Manchester
    1,065
    Post Thanks / Like
    Nice and easy job recently done mine and makes a differance its so warmer when the heaters are on oh and take the pipe of the plastic housing to make it easier !!
    1999 Audi A4 1.8T Quattro Sport - Volcano Black - Frankenturbo'd
    Wanted - S4 Skirt/Wing trims, S4 side skirt brackets.
    jamie226bhp's Avatar
    Aug 2009
    438
    Post Thanks / Like
    Hope u went genuine stat as I've had two non
    Genuine stick open on me in the past 10 months
    2000 A4 1.8 tqs scroll sp51, ths decat, milltek cat back with rs4 backbox, remap
    Royh1179's Avatar
    Jan 2012
    lincolnshire
    33
    Post Thanks / Like
    thanks guys i was going to get the stat from GSF in lincoln ,,, ow much do audi charge for a gen stat ???
    Aug 2009
    438
    Post Thanks / Like
    I paid 21 with the new gasket , both my others were from gsf
    Byzan Pics's Avatar
    Apr 2004
    10,704
    Post Thanks / Like
    Jamie, what is the colour of your car called?
    Royh1179's Avatar
    Jan 2012
    lincolnshire
    33
    Post Thanks / Like
    ok cheerz jamie
    Aug 2009
    438
    Post Thanks / Like
    Think it's brilliant yellow ill dig the code out
    VOLKSWAGEN-AUDI BRILLANTGELB LY1B 1994 - SOLID
  12. Thanks Byzan Pics thanked for this post
  1. Thermostat gone? any way to tell?
    By MrCSW in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th February 2011, 07:49
  2. Thermostat
    By michaelspirou in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th June 2010, 18:30
  3. where is my thermostat ?
    By white.akita in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th March 2009, 16:05
  4. Thermostat??
    By a3daveo in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th November 2007, 13:46
  5. THERMOSTAT
    By LULU in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2004, 05:11
