B5 1.8T THERMOSTAT ?!?!?!?!!??!!?!?
Royh1179
lincolnshire
hi all need to replace my stat has it seems to have jammed open as car stays way to cool,,, temp comes up when ticking over for a while and heaters blow warm but soon as i drive it cools back down,,,, so i guess its stat,, going to change it tommorow just seeking advice no fitting have been told i need to remove alternator ?? is this true or can i get to it from underneath as it looks like i can ??? whos done it and best way of getting it done ,,,,, thanks guys :thumbsup:
Easy from underneath, either fiddle the 2 x 10mm bolts out around the support bracket, or add a 13mm nut to the removal for better access.
The worst bit is the coolant running dowen your arm
thanks mate and yeah water down the arms this time of year isnt going to be enjoyed lol :thumbsup:
Nice and easy job recently done mine and makes a differance its so warmer when the heaters are on oh and take the pipe of the plastic housing to make it easier !!
Hope u went genuine stat as I've had two non
Genuine stick open on me in the past 10 months
thanks guys :thumbsup: i was going to get the stat from GSF in lincoln ,,, ow much do audi charge for a gen stat ???
Think it's brilliant yellow ill dig the code out
VOLKSWAGEN-AUDI BRILLANTGELB LY1B 1994 - SOLID
7
3K
44
4K
11
9K
15
