VAG CheckW8 Performance
Results 1 to 9 of 9
    Nov 2011
    lincoln
    43
    Post Thanks / Like
    any body know how much! or anybody got a drivers side front drive shaft + cv joint?
    it has been knocking slightly in full lock for a little while, 2day they split apart, had to get a mate to tow me back! all the way they were clucking! i fear the damaged is done. how hard are they do change, any info would be appriciated, thanks
    Nov 2011
    lincoln
    43
    Post Thanks / Like
    sorry the car is a 2000 plate facelift fwd
    audiv6quattro's Avatar
    Dec 2010
    East sussex
    388
    Post Thanks / Like
    HI andy I do remember seeing a thread with pics somewhere but can't remember where have a read through this though it should help taligentx.com: Passat - CV Boot/Joint Replacement
    1996 A4 2.6 v6 quattro,love the car hate the cost!!
    Dec 2010
    East sussex
    388
    Post Thanks / Like
    I know it's for a passat but pretty much the same
    Dec 2010
    East sussex
    388
    Post Thanks / Like
    Assuming yours is a 1.8 try here Driveshaft | Audi A4 1.8000 2000 | BuyPartsBy they do other engine sizes and parts aragorn recommended rid place to me the are very cheap.
    Nov 2011
    lincoln
    43
    Post Thanks / Like
    thanks audiv6quattro, for the quick response! i love my audi carnt let it sit still for more than a few days, i love driving it!
    Dec 2010
    East sussex
    388
    Post Thanks / Like
    No worries mate I love my audi to but hate it when anything goes wrong as it costs a bit more than your average car but the build quality is twice as good. Hope you get it sorted soon mate. Dan
    Banned
    Aug 2010
    1,043
    Post Thanks / Like
    a joint kit from gsf is around 60 quid i think. is it a manual? if it is its easy to change without stripping the suspension at all.
    crack off the hub center nut. 17mm allen key socket 1/2 inch big knuckle bar.
    jack the car up and support on an axle stand.
    remove wheel.
    undo the inner joint off the gearbox drive flange 6x10mm spline bolts. (when undoing them stick a wheel bolt back in the brake disc and slot a screw driver in the vented disc against the brake caliper to stop it turning while you undo them.)
    undo the center 17mm nut completely.
    grab your jack, stick it under the lower ball joint on the suspension and jack the suspension up to compress it till its at the point where its just starting to lift the car off the axle stand.
    get under neath and youll be able to slot the driveshaft out over the subframe. (you may need to put the 17mm allen key bolt back in the a couple of turns and tap the joint out of the splines in the hub to get it moving)
    get the driveshaft in a vice, remove old clips, cut old boot off. grab your hammer and knock the old joint off. (theres an inner tension clip holding it on the shaft)
    install new boot/joint (dont forget the new grease sachets) and refit.
    with air tools/2 poster ramp/transmission jack ive had this job down to sub 20mins. charged out usually at an hour and a quarter.
    Nov 2011
    lincoln
    43
    Post Thanks / Like
    got it fixed yesturday just b4 it snow`d like f___, got the pattern part but i really want the oem version but that was twice the price, was a little strap for cash but it was only 28+vat at gsf. any way this was so easy to change! was really impressed and only used 2 spanners!! glad to be back on the road. cv joint fell apart so only undid the hub bolt, knocked the old on out, slipped new one on drive shaft and in full left lock it almost went in, so a little tap of the hammer hay presto! gota say really love me a4, dont think i will eva get rid! ;-)
  1. S3 CV Joint/Drive shaft
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th June 2011, 17:33
  2. WANTED: front drivers side spring for 2002 S3
    By JD09 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th June 2010, 16:39
  3. Taking the outer CV joint off from shaft?
    By rickyquicky in forum General Technical / How To
    Last Post: 11th June 2010, 22:20
  4. Cv joint /drive shaft
    By 951 in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st July 2007, 18:22
  5. A6 4.2 Drivers Side Front Knocking Noise
    By cg084 in forum Handling
    Last Post: 20th March 2007, 16:58
