Nicked the photo from this thread (A3 Ibis White Black Edition Detail with Gtechniq)
This black plastic cap covers a star bolt item. What is it and what do it do?
Mine keeps going lose.
Could it possibly be to lubricate the inside of the hinge maybe
1996 A4 2.6 v6 quattro,love the car hate the cost!!
Could be a self destruct button for when you've had enough of the car and want a new one
Im sure(dont quote me thou) that its for slight adjustment of the door hinge!
Project RS28 build
Threads in the actual hinge may now be worn???
Do you have issues with that door alignment Scott?
Project RS28 build
When the door hinge drops into the A post hinge, that little bolt keeps the hinge in place. Have you replaced both parts of the hinge???
White B5 1.8 turbo sport
if your door drops (an mine has a bit), how do you "adjust" it...
2000, A4 2.5Tdi Quattro.
Tinted, 3600WATTSLoud
A jack and a piece of long wood under the door and a very gentle application of upwards pressure.
Going .....'56 Audi A4 2.0 TFSI Sline SE quattro Avant
To be replaced by a
11 plate SEAT Exeo CR ST Sport Tech
Try to slightly loosen the the bolts in the top hinge (going into the door) take the weight off the door then loosen the little bolt, give the top hinge a bit of a tap down to ensure the pin is sitting right in the other part of the hinge then re-tighten all bolts.
The discussion or talk about the best way or proper way to adjust the doors has been talked about in length.
Most people seem to want to bodge it by jacking or shuting the door with a 13mm socket in the hinge.
Like you, I opt for the better correct approach of undoing the bolts and adjusting the door.
.... never liked botching things,
i've tried looking tho and even looked on google (what a mistake), don't suppose you have the link to hand, by chance.
the "lifting" of my drivers door, the proper way![]()
.... those the 13MM ones yeah?
also i've jus read ya build post, v v v good read
the door blades you put on the back, they STD or modified ones, also where did you get the wind delectors from?
Wayne
ideal thanks :D
