KowalskiVAG Check
Results 1 to 9 of 9
    Jan 2012
    Malton
    29
    Post Thanks / Like
    How long does it take to replace wheel bearings on a B5 Quattro?
    Grindy wheel bearing starting to get on my thrupenny bits, is it complex to do? will it take a propa mechanic one hour? two?
    thanks,
    Tom
    Byzan Pics's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    10,704
    Post Thanks / Like
    front? Back?
    Few hours max, depending on stuck bolts and pressing the bearing in and out of the upright or hub. Pretty much the same time either front or rear
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,308
    Post Thanks / Like
    Rears are a doddle, not had to do a front one in the 70,000 miles I've had the car for
    Life begins at 140mph
    www.passionford.com
    Byzan Pics's Avatar
    Apr 2004
    10,704
    Post Thanks / Like
    On a quattro the rear and front bearings are one piece and really need a press to fit/remove. A 2wd is dead easy with a hammer and a punch
    Jan 2012
    Malton
    29
    Post Thanks / Like
    Thanks for the replies - its the rear bearings ona quattro
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    20
    Post Thanks / Like
    Need to do one on my car, again rear on quattro. As far as I know hub assembly needs to come off so you can get it pressed out, which means disconnecting ABS sensor, upper arm bolt, CV hub bolt, etc. Pretty sure it can't be done in situ?
    2002 A2 1.4 TDi SE (75PS)
    2001 A4 2.5 TDi Avant Quattro Sport (150PS)
    1995 80 1.9 TDi Avant SE (90PS) Sold
    Royh1179's Avatar
    Jan 2012
    lincolnshire
    33
    Post Thanks / Like
    sorry to invade this thread guys but what is the tightening procedure on a b5 1.8tsport rear bearing ( FWD / none quatro ) thank you
    "Stick a V8 in it!"
    Cleveleys, Lancashire
    11,839
    Post Thanks / Like
    I generally nip them up until you can only just move the big washer behind the nut with a screwdriver and that does it.
    For Sale: Breaking B5 A4 - Check my eBay page!
    Wanted: Facelift A4 Front Bumper with Headlight Washers.
    2000 A4 1.8T Sport Quattro Avant, Beere Pearl, TT Carriers and B6 312mm Disks.
    2000 A4 1.8T Sport Quattro Saloon, Black-ish, Now Running!
    1997 S4 - PPC £999 Challenge Track Car Build starting soon!
    Audi V8 powered Land Rover Defender build in progress.
    Royh1179's Avatar
    Jan 2012
    lincolnshire
    33
    Post Thanks / Like
    ye thats what i got told by a friend to do and have done and seems to be ok (quiet and no nasty noises or vibrations ) just prefer peace off mind espeshily as i carry my 3yr old in car,,,, thanks
  1. Wheel Bearings
    By Der_Techniker in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th November 2011, 15:46
  2. Wheel bearings
    By Oranoco in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th January 2009, 13:14
  3. Wheel Bearings
    By sharpr in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th February 2007, 16:17
  4. Wheel bearings
    By hamski in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2006, 11:55
  5. Audi 90 quattro wheel bearings..
    By patb in forum Classic Audi Forum
    Last Post: 19th June 2005, 12:28
