DTUKAWEsome GTI
Results 1 to 13 of 13
    Apr 2006
    A, A
    209
    Post Thanks / Like
    Rear wiper motor
    Ok, when I use the rear wiper it sometimes does a full sweep like it should but sometimes it sticks for a second or 2 and then continues it's journey.
    Is this a common thing?, motor, relay contacts?
    A4 Avant 1998
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,274
    Post Thanks / Like
    Blog Entries
    Motor.
    It's common.
    You can strip it down, clean, grease and try again.
    It might work and be fine, mine was for a week or 2 then started again.
    I've since binned the rear wiper all altogether.
    S4_dan's Avatar
    Jan 2006
    924
    Post Thanks / Like
    Ditto, stripped mine down and cleaned and worked for 2 weeks.
    New motor is too expensive to justify buying one and all 'working' 2nd hand ones are sold or robbed from scrappies.
    Dan
    Audi A4 B5 2.8 V6 30V Decats (Gutted out cats) FREE to whoever wants to collect from York. PM me.
    Holiday lets in Wells next to the Sea: http://www.wellsholidaycottage.com/
    Apr 2006
    A, A
    209
    Post Thanks / Like
    Mm, get rid all together sounds interesting, I take it you just get a blanking plug and is both of yours avants?
    Was looking at this
    GENUINE AUDI REAR WIPER MOTOR REPAIR KIT 8L0998711 | eBay
    S4_dan's Avatar
    Jan 2006
    924
    Post Thanks / Like
    I still have mine in situ and not done anything more with it as yet.
    Only Avants have the rear wipers.
    That kit is ok............as long as your motor hasn't suffered to much what with the mechanism seizing to due the poor design of running as water pipe through the midddle of the mech.
    Apr 2006
    A, A
    209
    Post Thanks / Like
    The wiper runs free but just stops every so often, sometimes it runs for days then others moves like a robotic dogs tail.
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,274
    Post Thanks / Like
    Blog Entries
    Quote Originally Posted by adidasandy View Post
    Motor fault. Comon on avants with in the vag range.
    I removed mine and put a glass plug in.
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    Bridgend, South Wales
    507
    Post Thanks / Like
    Theres washer fluid I bet inside the wiper motor!
    As has been said, its a poor design as the washer jet pipe goes through the motor mechanism, the pipe corrodes, fluid gets into the motor and the wiper literally develops a life of its own,lol.
    I simply replaced mine with a s/h wiper motor,5 years on its still OK, though you can get rebuild kits as mentioned above.
    On an Avant having no rear wiper isn't a wise move IMHO, you need one........
    '99 Ming Blue A4 Avant TDi SE 110 + Dragon Performance Tuning Box
    Factory sunroof / Aircon+Climate /Royale blue leather
    '72 1302LS Karmann Beetle Cabrio Silbermetallic
    '63 Karmann Ghia Sunroof Coupe Pacific Blue
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,274
    Post Thanks / Like
    Blog Entries
    Quote Originally Posted by S3Bangs View Post
    K... still on the standard discs as I couldnt wait to change the pads.. that light on the DIS was gettin on my t*ts! And I'd like to believe the mechanic greased the pads as the EBC pads came with some grease in the box and it wasn't in it when I picked the car up.
    The squealing is not constant though.. sometimes it does, sometimes it doesnt, other times it'll squeal immediately I press the brakes and stop long before the car comes to a halt... As its not constant, Im always questioning whether its mine squealing or the car beside me but it has happened with no cars around me, so I know theyre mine squealing.. and also is it the compound used in these EBC pads that make them stink this much?
    Why?
    Panel vans, lorries, bikers and saloons don't have them.
    "Stick a V8 in it!"
    Cleveleys, Lancashire
    11,839
    Post Thanks / Like
    Panel vans and lorries have no rear windows :P
    The shape of an avant/hatch bodyshell means you get an area of low pressure behind the car, which draws road spray up and onto the windscreen. As a result when driving in crappy weather you end up not being able to see much out the back window. Hence the wiper.
    Saloons dont need it because the sloping screen doesnt have the same issue.
    For Sale: Breaking B5 A4 - Check my eBay page!
    Wanted: Facelift A4 Front Bumper with Headlight Washers.
    2000 A4 1.8T Sport Quattro Avant, Beere Pearl, TT Carriers and B6 312mm Disks.
    2000 A4 1.8T Sport Quattro Saloon, Black-ish, Now Running!
    1997 S4 - PPC £999 Challenge Track Car Build starting soon!
    Audi V8 powered Land Rover Defender build in progress.
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,274
    Post Thanks / Like
    Blog Entries
    No rear window or dirty rear window.
    What's the difference?
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    The difference is i have a rear window and I want it to be functional.
    There is no law which says you must have a rear wiper, if thats what your getting at. Its just bloody annoying if you actually like to use the mirrors and cant see owt out of the rear screen!
    Ofcourse if your one of the many muppets that seem to use the mirrors for not much more than styling their hair and checking makeup, you probably wouldnt notice
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,274
    Post Thanks / Like
    Blog Entries
    Only mirror uses the rear screen. I got two more if it becomes unusable due to a dirty rear screen.
    Spent years driving vans. So I tend to forget about the middle mirror.
    The side ones does a good enough job.
    I use house mirrors all the time to make my self look pretty :D
  1. Rear wiper motor
    By jolly14 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th February 2011, 20:48
  2. rear wiper motor
    By olds_kool in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th September 2010, 22:03
  3. S3 rear wiper (motor?)
    By banoffee in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th March 2010, 12:43
  4. A4 Rear Wiper motor
    By b00zehound in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th September 2009, 15:09
  5. Rear Wiper Motor
    By S3DBW in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th February 2006, 23:47
