Sky InsuranceKowalski
Results 1 to 16 of 16
    Apr 2006
    A, A
    209
    Post Thanks / Like
    Electrical gremlins S4 B5
    1 = Display on centre of clocks starts to fade from the right after a few hours
    2= Bose sound system volume button won't function properly until it's warmed up (turn volume up it goes full blast, turn volume dome it goes silent ( nothing in between )
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,274
    Post Thanks / Like
    Blog Entries
    Quote Originally Posted by adidasandy View Post
    Bad contact with in the clocks.
    Its a common fault with the DIS screen.
    You can attempt a fix your self or send it away for repair.
    Byzan Pics's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    10,704
    Post Thanks / Like
    The Concert volume issue is common too sadly, the only real fix is replacement as it's a faulty chip that causes it.
    Apr 2006
    A, A
    209
    Post Thanks / Like
    So who is the best for carrying out thie repair, any recommendations?
    Quote Originally Posted by scott b5 View Post
    Apr 2006
    A, A
    209
    Post Thanks / Like
    Surely there must be something that can be done, wanted a nice stereo in it but like the standard look.
    Quote Originally Posted by Byzan Photography View Post
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,308
    Post Thanks / Like
    Rip the factory kit out and choose a replacement that matches in. Becker do a few superb decks.
    Life begins at 140mph
    www.passionford.com
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,597
    Post Thanks / Like
    Email Ian at <ebay@tektronics.co.uk>. I ran a Group Buy last year and he did an excellent job. Mine was terrible for years. It's perfect now.
    I've been through 3 concert stereos before I saw the light and went aftermarket. Wish I'd done it years earlier. I picked up a decent new CD stereo with a front USB port, rear aux port and it matches the OEM dash fairly well. Best of all, it only cost about £75 all in, including the loom adaptors.
    Edit: looks like they whacked the price up of the one I got- PIONEER 3200UB DIRECT IPOD CD RADIO. (4977729972498) | eBay
    Mo power, mo problems
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,274
    Post Thanks / Like
    Blog Entries
    Cluster repair did mine.
    I opted for the full service and 5 years warranty.
    Der_Techniker's Avatar
    Foursprung Duck Technique
    Oct 2010
    Coventry, West Midlands
    991
    Post Thanks / Like
    the issue behind it is that the chip stores the volume level on each adjustment, most aftermarkets and other OEMs store on power off. The chip will have a maximum number of writes to it before its full (say, 50'000) and as you can imagine, it will get used up pretty quickly. its either a matter of getting another audi unit (bose or none bose, as its only really coding that changes them iirc) or going OEM looking aftermarket as suggested
    2000 Silver Audi A4 1.8T Sport, With added Carbon Goodness
    "Arguing with an engineer is a lot like wrestling in the mud with a pig. After a few hours, you realize that he likes it."
    Apr 2006
    A, A
    209
    Post Thanks / Like
    Would really like to keep the same unit and get it repaired (will look into it further) and the clocks I will need to get done so thanks for the contacts.
    Andy
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,274
    Post Thanks / Like
    Blog Entries
    Quote Originally Posted by Der_Techniker View Post
    If its just a chip.
    Can you not clean or replace the chip for a newer version or a fresh one?
    Oct 2010
    991
    Post Thanks / Like
    They are one write non Eeprom. In theory you could replace, but I'm lead to believe they are rarer than the early 1.8t ecu chips
    Apr 2006
    A, A
    209
    Post Thanks / Like
    *****To reply to this message, please select the reply button. To help us expedite your inquiry, please be sure to include our original response.******
    Dear mr. *****,
    Thank you for your message.
    As you probably already know, the Sound System in your A4 comprises of the headunit/radio and our Sound System (speakers and amplifier). Since you mention volume problems and the fact that others seem to have experienced similar shortfalls, we assume that this is related to the Concert 1 radio -[ ON/OFF and volume knob in the center of the radio front plate?] The System was offered exclusively as an "off-factory" option by Audi, and therefore they insist on providing all service activities through their authorized dealerships. Therefore we are supposed to recommend that you contact your local Audi dealer.
    The radio Concert 1 can develop a behavior like you describe, and can be fixed at a Blaupunkt repair shop.
    Just in case you would not have any success with the Audi dealer, you could contact a company specialized in Blaupunkt radio repair.
    Blaupunkt (Concert-Repair) UK
    OE Electronics
    Units 5-6
    Four Brooks Business Park
    Stanier Road
    Calne-Wiltshire
    SN 119 PP
    Phone: 0044 (0) 1249 817370
    or
    Blaupunkt Stützpunkt (Concert/Delta-Repair) SRF Elektronik Service GmbH
    Brennaborstr. 10
    44149 Dortmund
    Phone : 0049 (0) 231 9650600
    Germany
    We have forwarded various customers to that address in the past and they confirmed the quality of the work provided. You may want to contact them for the current conditions of this repair activity.
    Please do not hesitate to contact us if you actually do not have the Concert 1 radio.
    Best regards
    Bose Automotive GmbH
    Customer Support Team Europe
    Frank Mueller
    Apr 2006
    A, A
    209
    Post Thanks / Like
    Byzan Pics's Avatar
    Apr 2004
    10,704
    Post Thanks / Like
    they are one of the good ones iirc, SRS had a group buy a while back and i'm sure that's who was used.
    Apr 2006
    A, A
    209
    Post Thanks / Like
    Thanks for that pal.
    Andy
  1. Electrical gremlins - any thoughts?
    By alanadams in forum A6/S6/Allroad forum (C5 & C6 Chassis)
    Last Post: 6th March 2012, 20:42
  2. Electrical Gremlins...............
    By macninja in forum A6/S6/Allroad forum (C5 & C6 Chassis)
    Last Post: 13th June 2010, 10:34
  3. A3 1.8T Q Sport electrical gremlins
    By jimmp in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th February 2009, 10:32
  4. 2004 A6 Electrical gremlins
    By singhl in forum A6/S6/Allroad forum (C5 & C6 Chassis)
    Last Post: 7th December 2008, 15:16
  5. Electrical Gremlins
    By Oranoco in forum A6/S6/Allroad forum (C5 & C6 Chassis)
    Last Post: 28th January 2008, 10:22
