DPMJBS
    Mar 2010
    Braintree Essex
    50
    Post Thanks / Like
    aux belt on 1.9tdi
    I have a 1999 a4 tdi, engine code afn and i need to do the aux belt and tensioner. How much of the front end needs to come off to tackle this job? Or can it be done with the front end on?
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    86
    Post Thanks / Like
    Just done mine recently, you can put the front end in the service position.
    Basically remove the front bumber, undo the screws each side on the front of the engine bay.
    Then you can slide the front forwards to generate space, not too far though.
    You can put some threaded rod in to hold it up.
    Don't get caught like I did, replace the tensioner on the alternator at the same time and then you won't have to take it apart twice.
    You do need a special tool to undo the alternator tensioner though, I borrowed from a mechanic I know.
    Mar 2010
    Braintree Essex
    50
    Post Thanks / Like
    Thanks for the info mate, wil get both tensioners done
  1. 1.8T Aux Belt Noise
    By Ekco163 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 30th April 2011, 18:09
  2. Help please - aux belt tensioner
    By Ian_83 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th March 2011, 18:56
  3. aux belt
    By williams in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 27th February 2011, 14:05
  4. Aux belt on a 2.0 TDI
    By M7R in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th July 2009, 19:39
  5. 1.8T Aux Belt
    By niggtv in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th May 2007, 18:12
