Chris NottMonster Motorsport
    imported_kenloen
    Amp in boot RCA lead question
    i already have a CD changer and am thinking of fitting a 4channel Amp in the boot. Where can i run the RCA leads? they wont fit under the kick plates and i would need to keep the Amp power lead and signal cables seperate .. any ideas
    Nov 2004
    Kent, UK
    138
    Re: Amp in boot RCA lead question
    I run my power cables down the drivers side of the car and the RCA leads down the passenger side. Both lots of cables are housed under the plastic inner sill trims - just inside the rubber door seals. They are held on by clips and can be carefully prised off.
    John
    Jun 2003
    World of my own
    9,813
    Yeah power down drivers side, as the easiest way through the bulkhead is through the ECU housing on the drivers side, saves having to route across the dash.
    imported_kris_tdi
    i have also done as said above.
