AWEsome GTIAMD Technik
    Oct 2010
    Ayrshire Scotland
    79
    Post Thanks / Like
    coolant temp sensor ?
    Wondering if anybody can help me fix this problem, occasionally the car will idle high, sometimes at idle, or at startup - if it does it at startup it's accompanied with a plume of black suit/smoke from exhaust,
    Ive only the one code on my vag-com, cant remember the code (will check later) but it definitely says coolant temp sensor? any idea's? is this related?
    Easy to replace Myself?
    audiv6quattro's Avatar
    Dec 2010
    East sussex
    388
    Post Thanks / Like
    What car is it mate
    Bradderz_1988's Avatar
    The only way is ..... German !
    Aug 2010
    Greater Manchester
    1,065
    Post Thanks / Like
    Thermostat will cause a coolant temperature sensor implausible signal code I kept getting this code, replaced the thermostat and hey no codes.
    Any car will naturally idle high say roughly 1000rpm on initial start up as the engine will be cold, the cloud of smoke may just be some unburnt fuel and exhaust gases.
    1999 Audi A4 1.8T Quattro Sport - Volcano Black - Frankenturbo'd
    Wanted - S4 Skirt/Wing trims, S4 side skirt brackets.
  5. Thanks ldoshiv2 thanked for this post
  6. #4
    Oct 2010
    Ayrshire Scotland
    79
    Post Thanks / Like
    its a 2000 1.9 tdi non pd mate, old ahu engine lol
    Thanks mate !, just strange, i could be sitting at a roundabout and i can see it rising from 800 to around 1100, either whilst engine is hot or cold, just serviced it so it aint dirty filters, maybe manifold needs a clean ?
  7. #5
    Dec 2010
    East sussex
    388
    Post Thanks / Like
    Ok hope this helps anyway, good luck Audifans.net: You are using an invalid IP
  8. Thanks ldoshiv2 thanked for this post
  9. #6
    Aug 2010
    Greater Manchester
    1,065
    Post Thanks / Like
    Try cleaning the maf sensor
  10. Thanks ldoshiv2 thanked for this post
  1. Temp Guage not working - coolant temp sensor changed... now what?
    By car4kids in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd February 2012, 19:10
  2. Is the coolant temp sensor plug the same as the coolant temp sender?
    By drfeelgood in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2010, 07:54
  3. Coolant temp sensor
    By SDO in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th September 2008, 20:56
  4. coolant temp sensor
    By potter in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th September 2007, 15:40
  5. Help! Where's the Coolant Temp sensor?
    By FactionOne in forum General Chat
    Last Post: 12th April 2006, 09:44
