AWEsome GTIForge Motorsport
Results 1 to 9 of 9
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    86
    Post Thanks / Like
    Snapped auxiliary belt on tdi
    The auxiliary belt just snapped on my 99 1.9 tdi.
    It is an AFN engine.
    Anyone know if it's a big job to get done
    "Stick a V8 in it!"
    Cleveleys, Lancashire
    11,839
    Post Thanks / Like
    You'll probably need to put the front end into the service position, which requires the front bumper off.
    I'd suggest you look at replacing the tensioner too, as often they'll snap because the tensioner is fubar!
    For Sale: Breaking B5 A4 - Check my eBay page!
    Wanted: Facelift A4 Front Bumper with Headlight Washers.
    2000 A4 1.8T Sport Quattro Avant, Beere Pearl, TT Carriers and B6 312mm Disks.
    2000 A4 1.8T Sport Quattro Saloon, Black-ish, Now Running!
    1997 S4 - PPC £999 Challenge Track Car Build starting soon!
    Audi V8 powered Land Rover Defender build in progress.
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,308
    Post Thanks / Like
    Done a Passat with the 1.9TDi without puling the front forward, found a reasonable amount of space to work in really.
    Life begins at 140mph
    www.passionford.com
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    Yeh passats have a fair amount deeper nose than an A4 though!
    I've done the belt on my 1.8T before and even in service position it was tight.
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,274
    Post Thanks / Like
    Blog Entries
    Same thing happened to my AFN.
    It went cause the tensioner was FUBAR.
    Drop the front end in to service mode, Remove the fan to make it life a bit easier, remove tensioner and redo.
    You will need a 8mm allen key to remove the fan.
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    86
    Post Thanks / Like
    Got it done today, not too much trouble.
    140euro for the tensioner and a belt.
    Seems fine, but the new tensioner seems a little loud.
    Maybe I'm being a bit paranoid, but there seems to be a lot of spring on the tensioner.
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    how much?!
    The tensioner i last baught was about 30quid!
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    86
    Post Thanks / Like
    I know!!
    You lads are spoiled in the uk with choice.
    Normally I order stuff over on the net, but this was unplanned and I use the car for a 120 mile round commute every day.
    What do you do?
    Normally I buy on eBay or from German parts direct, is there anybody else you would recommend for general parts
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    All German Parts are who i usually use. Dont know if they'd post to ireland though?
  1. Cambelt AND Auxiliary belt????
    By Ads in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th June 2011, 16:59
  2. Timing Belt snapped!!
    By Ciaranl in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th December 2008, 23:05
  3. Help - Auxiliary belt replacement cost
    By benr in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st November 2008, 16:29
  4. Disaster! A3 Cam belt failed but not snapped
    By Fandango80 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th June 2007, 09:25
