AH FabricationsBadger5
Results 1 to 7 of 7
    imported_wisethug0
    Another Chip question, not yet answered
    I just bought my 99 A4, and I was wondering what size chip (0.8 or 1.0) I should buy. I know that both require new DV's, and the 1.0 requires a new FPR. I commute this car to CSUN, and I would like to make it more powerful but not as to blow its load prematurely. Any suggestions?
    imported_wisethug0
    Re: Another Chip question, not yet answered
    anyone?
    AndyC's Avatar
    Apr 2003
    Dorset
    716
    1 bar is fine for these engines as long as the map is a good one with progressivly increased boost pressure.
    A.
    Jan 2004
    Northern New Jersey, USA
    91
    1 bar is definately your answer, whose giving you a .8 option, just curious?
    imported_wisethug0
    Neuspeed makes an 0.8 bar, and they are loctaed just a few miles away. I take it there is a big difference?
    Jan 2004
    91
    lets put it this way it will probably be noticable. Its just that most everyone does the 1 bar upgrade. So most of the results your seeing in the way of improved specs are for 1 bar chips. Check out www.speedtuningusa.com and their power chip.
    imported_wisethug0
    So is neupeed a good map?
