W8 PerformanceDTUK
Results 1 to 8 of 8
Thread: Oh so quiet....
    Der_Techniker's Avatar
    Foursprung Duck Technique
    Oct 2010
    Coventry, West Midlands
    991
    Post Thanks / Like
    Oh so quiet....
    Well after a prod from foxy, heres what I've been upto with the a4 recently.
    I've dynamatted the back end to help with the bass and various rattles, after finding a roll in halfords for a fiver
    Fitted a new stereo (kenwood) to replace the alpine unit (now for sale if anyone wants it) so I can have some more musical options (USB, iPod, aux, cd) instead of just iPod and cd.
    Replaced the front discs and pads, cv joints, and repaired the front bumper skirt (as it was catching on kerbs and the like).
    Next job is to book in an not to see what other issues are lurking before mine expires in may. Then tackle the rear discs pads and bearings not looking forward to that one... Will get abs rings and bolts ordered as no doubt they'll shear off...
    Pics to follow
    2000 Silver Audi A4 1.8T Sport, With added Carbon Goodness
    "Arguing with an engineer is a lot like wrestling in the mud with a pig. After a few hours, you realize that he likes it."
  2. Likes ScottB5 liked this post
  3. # ADS
  4. #2
    Sandra's Avatar
    Sep 2010
    West of Scotland
    4,706
    Post Thanks / Like
    Certainly sounds like you have been busy.
  5. #3
    Oct 2010
    991
    Post Thanks / Like
    Haha just a little, I'm sure it's a form of addiction, started with the intention of JUST doing the CVs lol... Now look what's happend and spend about £150 instead of £25
  6. #4
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,611
    Post Thanks / Like
    Project RS28 build
  7. #5
    Oct 2010
    991
    Post Thanks / Like
    ok, Bugger... no pics damn iphone has had to be restored
  8. #6
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,274
    Post Thanks / Like
    Blog Entries
    Quote Originally Posted by Der_Techniker View Post
    Should have gone android
    The rears are easy.
    Just make sure you got a press handy.
    the caliper bolts on mine was a *****.
    I replaced 2 or so i think.
  9. #7
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    20
    Post Thanks / Like
    Worth opening the bleed valve when you screw the piston bore back in. Can be a hassle at the best of time. I also use a little Lockheed red grease (for hydraulic applications) under the piston dust sleeves and on the slide bolts. Double-check the handbrake cable ends... which suffer corrosion, etc. If in any doubt - then replace. Unfortunately part is £50. I also dismantled handbrake spring on caliper as it was seized, grease up, etc. I fitted Bosch pads and Zimmerman discs.
    2002 A2 1.4 TDi SE (75PS)
    2001 A4 2.5 TDi Avant Quattro Sport (150PS)
    1995 80 1.9 TDi Avant SE (90PS) Sold
  10. #8
    jcb
    Sep 2005
    uk
    3,784
    Post Thanks / Like
    i have just done my rear brakes, both CV's and both bearings.
    Had to remove the calipers to get them wound in after fully removing the piston!
    in actual fact it was faster doing the second one this way that messing around with the poxy rewind tool.
    CV's were a doddle once I had pulled the shafts.
    did the bearings without a press using the patented (or not) pikey press free method!
    rear bearing job for pikeys or those without hydraulic presses
  1. Why is this section so quiet?
    By Vitchie in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 13th November 2010, 12:05
  2. miltek too quiet??
    By 20vtdaz in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th December 2007, 15:40
  3. How Quiet Is Your Work??
    By loafy in forum General Chat
    Last Post: 26th January 2007, 21:12
