JuicyDTUK
    king84's Avatar
    Spartacus
    Dec 2011
    Seattle, WA
    6
    Post Thanks / Like
    Question NEWBIE with a LIST
    Ok.... So i'm a newbie here. Originally from the Mazda247 world, but I wanted to try something new. I just bought a used 1997' 2.8 A4 (Qauttro/5Speed). I have a few things on the "laundry list" that I need to fix or figure out:
    • Adapter or deck to enable Ipod/iphone integration, but currently have a factory (Bose) radio with 6 CD Changer and mini amp in the trunk.
    • Looking for front passenger side door lower trim molding, not the whole set.
    • The best exhaust and header brands to look into for 97 2.8 Quattro, not 1.8.
    • Windshield washers are inop.
    • Power Steering pump noisy and leaking.
    • Left outer tie rod end wearing out.
    • Rear Differential side seals leaking.
    • Missing belly pan, but i doubt ill ever need it.
    • Looking to lower height.
    • Broken hood latch handle.
    • stock wheels are eh...ok i guess, but I'm sure there's better.
    • DAYTIME Running lights are a NO NO. Need help removing that feature.
    • K&N filters....... or keep it stock? I had a K&N on my old mazda and never had an issue....but I know i can't apply the same rule to my A4.
    ANY SUGGESTIONS.......please feel free to respond or message me.
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,308
    Post Thanks / Like
    Firstly, welcome to the board.
    Reading your post would indicate you're from over the pond. As best as I can advise bearing this in mind;
    • Adapter or deck to enable Ipod/iphone integration, but currently have a factory (Bose) radio with 6 CD Changer and mini amp in the trunk. - Fit aftermarket deck and bypass Bose amp, add own system and amps as you desire
    • Looking for front passenger side door lower trim molding, not the whole set. - Parts are still available from main dealer for sensible money here in the UK I would expect this to be the smae where you are
    • The best exhaust and header brands to look into for 97 2.8 Quattro, not 1.8. - Never looked at exhaust swaps for the 2.8, sorry
    • Windshield washers are inop. - Any noise from pump or whole system dead?
    • Power Steering pump noisy and leaking. - Replace with a new or good used pump
    • Left outer tie rod end wearing out. - Replace with new item and check all other ball joints on the front of the car as these can be problematic. Replace any parts with O/E quality items
    • Rear Differential side seals leaking. - Replace with new, renew fluid whilst there
    • Missing belly pan, but i doubt ill ever need it. - Don't worry about it
    • Looking to lower height. - Good quality springs on stock dampers if they are in good condition. Best bet is renew with proper dampers and springs or coilovers, depends on what you want to do with the car and your budget
    • Broken hood latch handle. - Second hand item sourced from a breakers
    • stock wheels are eh...ok i guess, but I'm sure there's better. - Take your pick, loads of options. Only limit is your imagination and budget
    • DAYTIME Running lights are a NO NO. Need help removing that feature. - We don't have them in the UK so can't comment on how to remove them, sorry
    • K&N filters....... or keep it stock? I had a K&N on my old mazda and never had an issue....but I know i can't apply the same rule to my A4. - K&N's are ok but as with any oiled filter they will typically cause fouling to the MAF. I put up with this and simply clean my MAF every couple of months with an electrical contact cleaner.
    Life begins at 140mph
    www.passionford.com
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,738
    Post Thanks / Like
    Super Sprint make the best header but there not cheap AUDI A4 QUATTRO (Sedan + Avant) 2.8i V6 (193 Hp) –› ' 00, exhaust system if you have the 12v then save your money and sell it if looking to do engine mods.
    If your car is running Spoer shocks then H&R Race spring work well or get your hand on some RS4 or S4 shocks if on a budget with H&R race springs
    Light rewire.
    AudiWorld Tech Articles
    04 Audi A4 B6 1.8TQ S-Line 190bhp 6 Speed Duel SMIC
    Milltek Exhaust|VMR boost Gauge|SP51 K04-15 Outlaw (K04-23+)|Samco Sport DV|034 Sport CAT (12bhp over stock)|Autobahn88 TIP|N75J Valve|
    To be fitted: B7 RS4 F-Brakes|SB Stage4 Clutch|380 inj|
  1. List of Problems
    By gaz_aot in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th June 2011, 20:12
  2. To do list...
    By rossbrownlee in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd September 2009, 20:16
  3. list of to do's
    By daveeeeee in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th June 2009, 10:28
  4. Problem list B5 S4!!!
    By andybnwc in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st October 2007, 14:33
  5. Problem List
    By godwine in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd February 2006, 08:23
