Badger5AWEsome GTI
Thread: Oil A4 1.8t
    Cam
    Dec 2010
    Sheffield
    29
    Post Thanks / Like
    Oil A4 1.8t
    Wich type of oil should i use for 1999 A4 1.8t
    For the last couple of oil changes ive used 5-30w semi synthetic as recomended by garage.
    Bradderz_1988's Avatar
    The only way is ..... German !
    Aug 2010
    Greater Manchester
    1,065
    Post Thanks / Like
    5w30 is a little thin you wanna use 5w40 fully synth !
    1999 Audi A4 1.8T Quattro Sport - Volcano Black - Frankenturbo'd
    Wanted - S4 Skirt/Wing trims, S4 side skirt brackets.
    Cam
    Dec 2010
    Sheffield
    29
    Post Thanks / Like
    i posted message earlier about oil pressure light could the oil be responsible for clogging oil strainer?
    Thanks for your help
    jcb
    Sep 2005
    uk
    3,784
    Post Thanks / Like
    i use Mobil 1 fully synth
    5W 30
    "Stick a V8 in it!"
    Cleveleys, Lancashire
    11,839
    Post Thanks / Like
    I run 5w40. 30 weight is a little on the thin side, espeically on higher mileage motors as most of these cars are now. They can end up with dangerously low oil pressure when hot.
    As for your oil light, i wouldnt think the 30weight oil is causing the light, most likely a clogged strainer or a worn out oil pump if its a particuarly high mileage engine. You'd really need a pressure guage to tell for sure though, and dont even consider driving it around until you've worked out why the light is on and fixed it, or you'll be replacing the engine.
    For Sale: Breaking B5 A4 - Check my eBay page!
    Wanted: Facelift A4 Front Bumper with Headlight Washers.
    2000 A4 1.8T Sport Quattro Avant, Beere Pearl, TT Carriers and B6 312mm Disks.
    2000 A4 1.8T Sport Quattro Saloon, Black-ish, Now Running!
    1997 S4 - PPC £999 Challenge Track Car Build starting soon!
    Audi V8 powered Land Rover Defender build in progress.
  1. Fitting an oil pressure / oil temp and boost gauge...
    By JonBoi21 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2011, 17:23
  2. Replacing diff oil & gearbox/transmission oil tomorrow
    By The Doctor in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th September 2011, 22:10
  3. S3 engine oil, transmission oil, haldex oil, rear dif oil and front dif oil?
    By colicabcadam in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th September 2010, 17:49
  4. Oil level low warning light - what oil to buy, on xmas day?
    By drewbee in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th December 2009, 11:32
  5. Metal Impeller Waterpump & Haldex Oil filter/Oil
    By Hardsy in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2007, 17:08
