Forge MotorsportDTUK
Results 1 to 8 of 8
    B5QUAT's Avatar
    Apr 2011
    Manchester
    206
    Post Thanks / Like
    Could someone "in the know" please check this part number for me? S4 brake upgrade.
    Hi,
    I'm just about to splash out on the caliper carriers for doing the 345mm B6 S4 front brake conversion on my car. I've already managed to get a set of B5 S4 uprights 2nd hand and I've tried for months to get some 2nd hand B6 S4 calipers and carriers without success.
    I can get the discs pads and calipers new from All German Parts but I'm told the carriers are Audi only. Apparently they are about £150 each side from the dealer! But the hell with it. I'm fed up of waiting and fed up of poo brakes.
    I've done a bit of homework and it seems that the part number I need is 1K0 615 125C which is apparently with a black finish (if the suffix is B they are apparently silver). I prefer black as I want it as OEM looking as possible.
    Now the question is a) is this the correct part number and b) is it the same part number for both sides (ie do I order 2x 1K0 615 125C) or not?
    Also, when you google this part number it comes up with a load of stuff on Mk5 Golfs. Is this also a VW part and if so, would it be cheaper from a VW agent perhaps (much more Mk5s about than S4s)?
    Any help would be appreciated before I spend £300 of my hard earned to find out that they don't fit!
    Ming Blue 1999 1.8TQS. Mods so far: full non res Milltek, decat pipe, Weitec Ultra GT suspension, Meyle front arm kit, 18" BBS LM reps, interior LED upgrade, Advanced tuning chip (20psi), Pipercross filter. Planned mods: FMIC, B6 S4 brake setup, RS4 Clutch, ECS flywheel, GT28RS conversion and custom remap.
    VW/Audi parts advisor
    May 2010
    Bedford
    1,220
    Post Thanks / Like
    1K0 615 125C is golf/a3 fitment only. No mention of S4 at all on ETKA and is for 312mm brakes. 1K0615125B is the number you want which is for S4/A4/Passat/Eos/A6 blah blah blah. £145.89 inc vat each
    Laser Red 98 A4 1.8T - B7 A4 17" wheels, Weitec GTN coilovers, Front strut brace, Custom rear dual strutbrace, Custom rear floor brace, RS4 front lower subrame brace, Neuspeed rear Antiroll bar, Shortshift with lever extension, Silicone TIP, Jetex cone, Forge 007p, Jetex 2.5" catback exhaust, THS 3" Decat, Custom downpipe, 312mm Front brakes, RS4 Engine Mounts, RS4 Snub mount, Audi 80 TDI solid flywheel, Audi S2 3B clutch kit, Rtech mapped
    199bhp 221ft-lbs
  4. Thanks B5QUAT thanked for this post
  5. #3
    Bradderz_1988's Avatar
    The only way is ..... German !
    Aug 2010
    Greater Manchester
    1,065
    Post Thanks / Like
    Will these not do 110801923506 ?? As you could sell the rears don't no if there 345mm but there good stoppers as I drove a seat cupra r with these fitted and there keen as fook lol
    They ended with no bids might be worth a shot !!
    1999 Audi A4 1.8T Quattro Sport - Volcano Black - Frankenturbo'd
    Wanted - S4 Skirt/Wing trims, S4 side skirt brackets.
  6. Thanks B5QUAT thanked for this post
  7. #4
    "Stick a V8 in it!"
    Cleveleys, Lancashire
    11,839
    Post Thanks / Like
    The R32 front brake calipers and carriers are more or less the same as the B6 S4 ones.
    The main differences are the caliper piston is only 57mm instead of 60, and they're blue.
    The piston issue isnt that big a deal, as the stock 288 calipers also have a 57mm piston. Staying at 57mm means they wont be quite as powerful as the B6 ones (marginally), but you'll also retain a more solid pedal feel as a result.
    The disks wont fit however, as the offset is different.
    For Sale: Breaking B5 A4 - Check my eBay page!
    Wanted: Facelift A4 Front Bumper with Headlight Washers.
    2000 A4 1.8T Sport Quattro Avant, Beere Pearl, TT Carriers and B6 312mm Disks.
    2000 A4 1.8T Sport Quattro Saloon, Black-ish, Now Running!
    1997 S4 - PPC £999 Challenge Track Car Build starting soon!
    Audi V8 powered Land Rover Defender build in progress.
  8. #5
    B5QUAT's Avatar
    Apr 2011
    Manchester
    206
    Post Thanks / Like
    Thanks!
    So, could I get those calipers and carriers that Bradderz posted up for a mk5 R32, then I'd just need B6 S4 Discs and R32 pads? What about brake hoses? Would my B5 hoses fit the R32 calipers?
  9. #6
    Aug 2010
    Greater Manchester
    1,065
    Post Thanks / Like
    Remanufactured ones here 270885698967
  10. Thanks B5QUAT thanked for this post
  11. #7
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    For the brake hose, the B6 S4 has a metal bracket bolted to the caliper which takes a short length of hard line, much the same as your existing caliper. The hose from that bracket to the chassis is then just the standard B5/B6 A4/S4 hose.
    The R32 caliper may not have this bracket/hardline, so you may need to buy them from the dealer, but they're not too expensive.
  12. #8
    B5QUAT's Avatar
    Apr 2011
    Manchester
    206
    Post Thanks / Like
    Great info, thanks! Might as well get those remanufactured R32 Calipers and carriers then. They are the same money as just the S4 carriers from Audi
  1. door latch part no "8L2 837 015 B"
    By Taff D in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd July 2011, 15:42
  2. Selling my S3 Number plate - "S3 AUY"
    By S3AUY in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th February 2009, 18:30
  3. Brake upgrade on standard 17"s
    By scib4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th April 2007, 10:31
