Backdraft MotorsportAdrian S Flux
    Jan 2012
    Post Thanks / Like
    2003 A4 Avant 1.9Tdi....engine problem
    Can anyone help me with a problem that has just occured on my vehicle.......I have been experiencing my brake lights coming on once the car has been left left switched off and locked...mostly when its cold outside and at night???
    Then over the past two days whilst driving the ESP warning light comes on and shortly after that I have no accelorator.....if left the Glow plug light lights up flashing, however I turned the ignition key one 1/4 turn back and then forward again and the lights clear and I have normal driving capability?....this will happen randomly and depending on the length of journey may happen a few times then clear all together. Then engine still runs when I lose accelerator, which leads me to think this is an electrical problem, rather than mechanical.
    When I start the engine, it goes through the checks and all warning lights extinguish revealing no problems!!!
    Has anyone experienced this very strange and worring problem? if so what was the cause/fix?
    Rgds
    Daz
    Jan 2011
    northants
    84
    Post Thanks / Like
    replace brake light switch
  1. Replacement cost for Inner CV Joint & Boot/ Axle- 2003 A4 1.9TDI Avant auto
    By larry1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st October 2011, 15:34
  2. 1.9tdi late 2003 avant sport 140k miles - things to budget for?
    By p1tse in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th May 2011, 20:05
  3. audi avant tdi sport diesel, 2003,engine races when cold
    By darcar in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th September 2010, 19:26
  4. Avant 1.9tdi gearbox problem
    By stonehands in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th March 2009, 19:04
  5. Replacing engine mountings on '96 A4 1.9tdi Quattro Avant
    By chuffy in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th March 2006, 15:26
