GNJW8 Performance
Page 1 of 2 12 LastLast
Results 1 to 50 of 76
Like Tree1Likes
Thread: MOT changes next year.
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,274
    Post Thanks / Like
    Blog Entries
    Thought I'd pass on this thread in the 8P section about MOT changes next year.
    MOT changes from april 2012
    CHEZ's Avatar
    puppy patrol.
    Jul 2011
    the lovely north east
    1,571
    Post Thanks / Like
    nice one scotty dog!
    as it happens just booked mine for next wednesday!
    Der_Techniker's Avatar
    Foursprung Duck Technique
    Oct 2010
    Coventry, West Midlands
    991
    Post Thanks / Like
    Headlight requirements are updated to take account of the particular characteristics of High Intensity Discharge (HID) lamps.
    HID headlights can cause dazzle if they are dirty or aimed too high so car manufacturers must fit headlamp cleaning and levelling systems. A car will fail if a mandatory headlamp cleaning or levelling system is missing, doesn't work or is obviously defective.
    Well mines fine then. Just looked at the updated test manual, and it doesn't specify "automated" levelling systems, so the thumbwheel and headlamp wash will do just fine
    2000 Silver Audi A4 1.8T Sport, With added Carbon Goodness
    "Arguing with an engineer is a lot like wrestling in the mud with a pig. After a few hours, you realize that he likes it."
  5. Likes ScottB5 liked this post
  6. #4
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,096
    Post Thanks / Like
    Quote Originally Posted by Der_Techniker View Post
    YES it does so you will have a fail :
    Vehicles equipped with High Intensity Discharge
    (HID) or LED dipped beam headlamps may be fitted
    with headlamp washers and a suspension or
    headlamp self levelling system.
    Where such systems are fitted, they must work;
    however, it is accepted that it may not be possible
    to readily determine the functioning of self levelling
    systems. In such cases, the benefit of the doubt
    must be given.
    Headlamp washers may work in conjunction with
    the windscreen washers (when the dipped beam
    headlamps are switched on) or by a separate
    switch.
    HID lamps may be identified by:
    • taking a few seconds to reach full intensity
    • having a bluish tinge to the light
    • having an igniter module/inverter behind the
    headlamp
    • having ‘DCR’ marked on the headlamp lens.
    HID headlamps use high voltage and extra care
    should be taken when inspecting these items.
  7. #5
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,308
    Post Thanks / Like
    Here's the crucial bit that makes the fitment of retro fit HID kits a non fail item
    Quote Originally Posted by paul20v View Post
    must be given.
    switch.
    headlamp
    Because of the wording used in the manual it would be incorrect to fail a vehicle with a HID kit fitted irrespective of whether it has self levelling and washers or not. Again it's down to headlamp alignment and pattern
    Life begins at 140mph
    www.passionford.com
  8. #6
    "Stick a V8 in it!"
    Cleveleys, Lancashire
    11,839
    Post Thanks / Like
    Depends if thats the exact wording though. UK Law doesnt allow HID's at all directly. European Type approval overrides the UK construction and Use regs however, and the type approval for HID's states they must have washers, and an automatic levelling system either on the headlight, or the vehicle as a whole.
    For Sale: Breaking B5 A4 - Check my eBay page!
    Wanted: Facelift A4 Front Bumper with Headlight Washers.
    2000 A4 1.8T Sport Quattro Avant, Beere Pearl, TT Carriers and B6 312mm Disks.
    2000 A4 1.8T Sport Quattro Saloon, Black-ish, Now Running!
    1997 S4 - PPC £999 Challenge Track Car Build starting soon!
    Audi V8 powered Land Rover Defender build in progress.
  9. #7
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,308
    Post Thanks / Like
    Absolutely correct. However the may wording is used in the official document and as such retrofit HIDs remain an MOT pass as long as theaim and beam patern comply. Their use on the highway remains unlawful as you suggest
    www.passionford.com
  10. #8
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,096
    Post Thanks / Like
    Quote Originally Posted by Oranoco View Post
    Your bang on
    ive read this and never clocked the MAY word
    so basically they have stuffed it and as said its no different to whats its always been .
  11. #9
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    Thing is, a) they may well simply amend it before its implemented.
    b) if your tester ignores "may" and fails you, your only option at that point is to appeal to vosa, on the grounds that while you DO have illegally fitted HID's, they put the word "may" into the testers handbook...
  12. #10
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,096
    Post Thanks / Like
    i doubt they will amend it as that is straight off the computer system word for word thats the fresh update , you never know but i will be suprised if they do .
  13. #11
    jcb
    Sep 2005
    uk
    3,784
    Post Thanks / Like
    why not avoid the retest and just put bulbs in for the test
    takes seconds
  14. #12
    Goosey's Avatar
    Jun 2011
    York
    35
    Post Thanks / Like
    not the first option, first you should ask the tester to point out in the manual to you where it's states it's a fail.
    people can misread things so it can easily be resolved, involving VOSA at the moment could turn messy for the tester and testing site considering a lot are losing their jobs this year
  15. #13
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    You really think its going to turn messy for the tester, failing a car that ACTUALLY HAS illegally fitted headlights due to what is effectively a typo?
    Why not just do the job properly, and if you want to use HID's, add the appropriate features that the law requires? The features arent there for fun, they are there so you dont blind other drivers, which i'm sure you'll agree is a fairly useful feature. Or maybe you've never had the pleasure of driving along a dark country road and finding some berk coming towards you in his chavved up hatch with retrofitted HID's burning your retinas out?
    I shall admit that my car does currently have HID's without levelling and washing, however the levelling kit is in the shed and the washer parts are mostly laying in the garden, so its merely a matter of finding some time to install them, and they will certainly be on there by the time MOT comes around.
  16. #14
    Goosey's Avatar
    Jun 2011
    York
    35
    Post Thanks / Like
    you can't say that till you've fitted them lol
    and it's not a typo, that really is how it is so any tester who fails one and it leads to appeal they would get 20 points straight off if unlucky
    reason i say at the moment it becasue VOSA had to cull 200 staff a year ago and i hear another 500 will go this year so they are out and about trying to catch testing stations out to justify their jobs rather then the old normal site visits.
    it was only a couple of weeks ago i had a ford ka sat behind me with some really bad HID's fitted, problem was made worse from oncoming cars putting main beam on in MY face to expose their anger :|
  17. #15
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    Exactly, so i see no problem with failing the ****ers and getting them off the road. Its rare i see a retrofitted car that DOESNT have rediculous glare.
    Ofcourse its a typo. The law specifies that cars with HID's MUST have washers and levelling. The manual says they may have washers and levelling. How can that be anything other than a typo. If the law requires them to be fitted, and your going to improve the MOT test to check for them, then why on earth have they put the word "may" in there. The only possible explanation is that its a mistake.
  18. #16
    Goosey's Avatar
    Jun 2011
    York
    35
    Post Thanks / Like
    take a look at all the imported cars we have in this country that have ALL gone through SVA's
    i'll use the integra as example seeing as i know them well, a lot of the later "98 spec" ones came with HID's from factory and they don't have self leveling or washers.
    the MOT has to be as clear as possible and you'll find they have gone slightly backwards on this as it's not straight forward enough to work out if a car has standard fit HID's or not, that comes down to product knowlage.
    the cheap tat that most have fitted is down to the traffic police to sort unfortunatly
  19. #17
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    Theres no way the cheap tat would pass the beam pattern checks of the MOT, so surely they'd fail on that?
  20. #18
    Goosey's Avatar
    Jun 2011
    York
    35
    Post Thanks / Like
    if that wasn't right then yes they would :-)
  21. #19
    Aug 2010
    23
    Post Thanks / Like
    how do i get around my airbag light, have bucket seats and harnesses the only thing left connected is the passenger airbag, so even if i put the steering wheel back and refit my seat belts and plug them in i still have a light on as the seat airbag isnt connected!! can i link them out with a resistor? or is that "not allowed". some things are very vague and open to alot of interpretation. if it passes this time ( march) and the issues listed as advisories would vosa still rape me if pulled over?
    god damn it just got the car how i wanted it!!!!
  22. #20
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    could always remove the airbag warning lamp from the cluster?
  23. #21
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,274
    Post Thanks / Like
    Blog Entries
    Then its a instant MOT failure.
    The ABS Light needs to come on and then go off.
  24. #22
    Oct 2010
    991
    Post Thanks / Like
    Yeah that is correct Scott. IF he was talking about abs
    The airbag system can be fooled by adding a resistor, though the value escapes me. Or blank off the light (or pull it out) i'd have to blank off the led as its soldered to the board, yours may simply be a bulb
  25. #23
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,274
    Post Thanks / Like
    Blog Entries
    I've all ways been told its the same for Air Bags.
  26. #24
    Aug 2010
    23
    Post Thanks / Like
    my girlfriends car is in for its mot on saturday so will have to find out what is required, shame you cant just take the whole system out but thats not ok either, although you are allowed to remove the abs system as long as all components are removed...... theres just no logic to it!
  27. #25
    S4_dan's Avatar
    Jan 2006
    924
    Post Thanks / Like
    IIRC, the Airbag light is monitered. I'm certain that the MOT tester last year was on about it when I took a Clio in that I was selling. Sometimes the light would stay on for alot longer than a start-up check but it did always go out within 5mins of driving. I said about pulling the bulb out and he didn't look impressed at all!
    Audi A4 B5 2.8 V6 30V Decats (Gutted out cats) FREE to whoever wants to collect from York. PM me.
    Holiday lets in Wells next to the Sea: http://www.wellsholidaycottage.com/
  28. #26
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,274
    Post Thanks / Like
    Blog Entries
    I got a feeling it will become a fail when it all changes in April.
    I'm trying to find the answer but other forums are saying it will be.
  29. #27
    OldRedEyes's Avatar
    424
    Post Thanks / Like
    I personally hope they fail every car with non standard, non factory fitted HID's as i am so fed up with getting dazzled by them. It does my firkin' head in.
  30. Likes colicabcadam liked this post
  31. #28
    Banned
    Aug 2010
    1,043
    Post Thanks / Like
    nope if the car had airbags as standard. even if you rig the light to come on and go off.....
    if it obviously has no drivers airbag in the steering wheel..... it will fail under "components missing" reguardless of the light seemingly working.
    as for hid's i'll be failing after market bodged in systems..... "may" or not.
  32. Likes ScottB5 liked this post
  33. #29
    Oct 2010
    991
    Post Thanks / Like
    Quote Originally Posted by OldRedEyes View Post
    Now I will hold my hands up and say I don't have "factory xenons". But my aftermarket ones have the correct beam pattern, no scatter, and are as good as the OEM ones. Though I have made a spacer to ensure the focal point of the lamp is the same as the halo variant. Moving the burner approx 3mm back.
  34. #30
    Banned
    Aug 2010
    823
    Post Thanks / Like
    good news in my eyes, should see less idiots with HID's on the road in their "broadcast" type headlights, the amount of times i have lost visual contact with the road because of these idiots with HID's in a normal type headlight is stupid
  35. #31
    Oct 2010
    991
    Post Thanks / Like
    Quote Originally Posted by colicabcadam View Post
    I whole heartedly agree. ive been in the same position, but when they are set up correctly in a near identical lamp to the OEM, they are no worse than OEM...
    sorry had to fight my corner before i get flamed at some point no doubt...
    Oranoco likes this.
  36. #32
    slepy's Avatar
    Sep 2009
    MK
    572
    Post Thanks / Like
    I don't want to raise any not necessary discussion here but I had a A6 special edition few months ago for few weeks and I was surprised how high headlights were set. Now driving in a S3 8P it's exactly the same. In fact when I had HID kit fitted to my B6 they were lower than the ones in A6 and S3.I did lower them a bit not to blind other drivers and never had anyone flashing me etc.
    2001 Focus 1.8 TDdi GONE
    1994 BMW 318IS GONE
    2003 Mondeo 2.0TDCI
    Zetec S GONE
    2002 A4 1.9 T
    DI in silver, with blue interior and RS4 style alloys. GONE
    2006 VW Touareg 2.5 TDI SE in sky blue GONE
    2007 A4 S-Line Special Edition Quattro 2.0 TDI 170 in silve
    r GONE
    2007 Seat Leon FR Tdi in yellow :D
  37. #33
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,308
    Post Thanks / Like
    Couldn't agree more. When installed as decribed and set up correctly there are no issues at all.
    www.passionford.com
  38. #34
    Goosey's Avatar
    Jun 2011
    York
    35
    Post Thanks / Like
    Quote Originally Posted by murran View Post
    we'll know who to blame when one day only VOSA can test vehicles due to NT's doing what they want :-)
    as for the airbags then you've have to prove that SRS wasn't standard on your car, can be done by removing components on a car where SRS was an optional extra, benafit of doubt would lie with the presenter.
    if it's anything newish or known for them all the have SRS then unfortunatly it's all going to have to be there and working.
    i must admit i thought/hoped that the SRS would have fallen into the same criteria as ABS.
    or at least covered by the same loophole for drivers seat adjustment for fixed bucket seats
  39. #35
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,308
    Post Thanks / Like
    Be interesting how this effects my brother as he converts cars for disabled drivers which often means removal of the airbag for the fitment of hand controls.
    www.passionford.com
  40. #36
    Goosey's Avatar
    Jun 2011
    York
    35
    Post Thanks / Like
    it won't, we've got a customer that has the same problem as it needs a modified steering wheel.
    there's a section about specialised modifications that covers doors and seats, nothing in the SRS section though, can't see it being a problem
  41. #37
    Mar 2012
    sbrewsbury
    Post Thanks / Like
    After april the airbag light will be testable and it must work and must not stay illuminted the new criteria also states any airbag missing be it dash steering wheel or seats etc if any have been removed the car will fail
  42. #38
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    I'm not so sure on the air bags.
    Surely if you can prove they're simply not fitted at all, rather than being fitted but being broken and you've masked the light...
    My track car has no airbag ECU, no airbags and no airbag wiring.
    The rumors floating round seem to be that if its obviously a proper competition car the tester can use his discretion:
    Road legal track cars & new MOT rules....thoughts?
    New MOT regs
  43. #39
    Goosey's Avatar
    Jun 2011
    York
    35
    Post Thanks / Like
    had a tester on a refresher recently and some of these questions came up, seems VOSA staff have mixed/incorrect opinions on some items.
    for example the requirements of a steering lock, the tester said he was told any electronic immobiliser (standard or aftermarket) meets the criteria but one of these aftermarket locks doesn't??
    how the hell does some alarm lock the steering lol
    either VOSA are seriously failing at teaching more than normal or people are not listening
  44. #40
    jcb
    Sep 2005
    uk
    3,784
    Post Thanks / Like
    I will class myself as a rarity then!
    I have been through three MOT beam pattern tests without issue.
    Was pulled by the Police (undeservedly I may add) and despite it being at night and them looking for a reason to apply some paperwork they didnt pick them as aftermarket.
    I have never been flashed to my knowledge either
    I suspect that if I had the MOT done at Kwikfit that they wouldnt even know they were aftermarket.
    Without removing the headlamp or putting it on a ramp and removing the undertray you cant see any external wiring.
    the only other way is to remove the back of the headlamp unit and hunt around for the H7 connector the HID power is plugged into. still not easy to find unless you knew what you were looking for.
    Same goes for airbags. If you have your circuit properly "resistored" to deal with lights coming on and going off and a dummy steering wheel airbag or aftermarket wheel there is no reason for them to fail you.
  45. #41
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    Yeh, projector headlamps tend to be a lot better, but they're still not always perfect, and so still suffer scatter due to the differing focal points between the two types of lamp. You can often improve things by dismantling the unit and spacing the reflector bowl away from the lens, or alternatively spacing the bulb back from the holder slightly.
    Passing an MOT or even a police stop check doesnt mean the lights are ok, it just means they didnt notice any issues.
    Same only goes for airbags if you still have the original equipment to resistorise/stealth.
    My track car project has no carpets, no airbags, no airbag wiring, no airbag ECU etc etc.
  46. #42
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,096
    Post Thanks / Like
    This is Direct from the testers manual .......
    Method of Inspection
    1. As far as practicable, check that all airbags fitted as ORIGINAL EQUIPMENT are present and not obviously defective.
    2. Turn on the ignition and check the presence and operation of any Supplementary Restraint System (SRS) malfunction indictor lamp(s) (MIL).
    Reason for Rejection
    1. An airbag obviously missing or defective. Note: A passenger airbag that has been switched off is not a Reason for Rejection.
    2. A Supplementary Restraint System (SRS) malfunction indicator lamp: · inoperative · indicating a system malfunction.
    This inspection applies to airbags, seat belt pretensioners and seat belt load limiters fitted as ORIGINAL EQUIPMENT .
    Theres no let up for track day cars that i can see looking through the manual
    if the car was fitted with them it has to have them for a UK test .
  47. #43
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    Yeh, but if you read the links i posted, Testers have specifically asked VOSA about competition and track day cars and were told they were fine...
  48. #44
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,096
    Post Thanks / Like
    Yeah until your local VE comes round and catches you not failing a car and says "whats the manual say"
    if its in the manual it has to be adhered to and until its there in black and white a tester is just asking to be busted for not failing an item clearly stated in the manual as a fail .
  49. #45
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    Why dont you ask them yourself when you have your seminar about the new rules then?
  50. #46
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,096
    Post Thanks / Like
    seminar
    thats another mine field
    already had a seminar and theres no more scheduled for a while
    also not due a refresher course for another 3 years
    problem is whats said on seminars and refresher courses is " whats it say in the manual "
    thats the answer for everything so as a tester our hands are tied and i for one cant afford to lose my job so the manual is the guide to which i for one follow .
  51. #47
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    Yeh i can see what you mean, it just seems weird that other guys have been told that cars specifically modified for competition use are fine. That bit you pasted doesnt mention anything about disability cars being exempt either, and yet you can be sure if the airbags were removed because the car was adapted for a wheelchair user, it would be allowed just fine.
  52. #48
    Banned
    Aug 2010
    1,043
    Post Thanks / Like
    this has been directly asked.
    apparently cars that are obviously "extencively" modified for a purpose, are exempt from these new failure items.
    by extencively i mean fully rally/track car prepped. that means not just an after market steering wheel or bucket seats/harnesses on their own in an otherwise standard car..............
    Thank you for your e-mail enquiry dated 9th February 2012, concerning ABS/SRS removal.
    The information column in Section 3.4 of the Private passenger MOT inspection manual states that "If an ABS or ESC system has been intentionally rendered inoperative, the whole system must be removed. However, this does not apply to sensor rings or other ABS components which are an integral part of another component e.g. brake disc or drive shaft"
    We are aware that the inspection of many of the new testable components may adversely impact modified vehicles. We have therefore made provision for most modifications to be accepted, provided that the vehicle is in fact extensively modified to meet a particular purpose, rather than simply modified on a whim and a fancy.
    The Introduction of the 2012 MOT Inspection Manual will therefore be amended at the end of April to coincide with the commencement of testing the new components. It will state:
    Modified Vehicles
    Where a vehicle has been extensively modified or converted, Reasons for Rejection for components missing where fitted as standard should not be applied, for example:
    • a car converted for rally use (i.e. rear seats removed and fitted with a roll cage and full harness seat belts etc.) may have been converted so as not to require a brake servo or power steering
    • a car converted to a stretch limousine may no longer be fitted with curtain airbags
    Additionally, Section 5.1 of the Manual will be amended to state: "An adult harness belt comprising a lap belt and shoulder straps bearing an FIA, British Standard or European approval marking (an upper case ’E’ or lower case ‘e’ and a number) is an acceptable alternative to any of the seat belt types listed"
    It is also worth pointing out that Section 6.2 of the Manual, on Seats and Doors, already contains a note in the Information Column which states: "Original design characteristics and specialised modifications (e.g. to enable wheelchair access) are to be accepted"
    It must be remembered however, that modifications can only be accepted so long as they comply with the Road Vehicles (Construction & Use) Regulations 1986 and the Road Vehicles (Lighting) Regulations 1989 as amended.
    I hope this information has assisted you with your enquiry, but if you have any further questions please do not hesitate to contact us again.
    Kind Regards,
    Robert Evans
    Customer Service Centre
    VOSA Operations Directorate
  53. #49
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    Was just about to link this:
    Weekend Racer - Update from VOSA re MOT regs
    Which has the same reply. Seems its just not made it into the manual yet...
  54. #50
    Banned
    Aug 2010
    1,043
    Post Thanks / Like
    "modified for a purpose" in my eyes is alot more than just sh1t missing and airbag lights on in a chavved up saxo dropped on its arse with 18" chrome rims and a flip laquer paint job.......
    altho, you could argue that the said saxo is modified for the purpose of making the driver of such a car look like a total knobhead..... so being modified for that purpose means...... it would have to pass.
    having such exemptions opens up a whole grey area meaning they may as well not have bothered at all with the new failure items in the first place!!
  1. MOT passed for a 13 year old car
    By ScottB5 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd November 2011, 13:30
  2. Mot failure same as last year?!
    By mephisto in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th June 2011, 09:50
