AMD TechnikDNA Tuning
    Dec 2011
    Post Thanks / Like
    2.5 tdi Quattro loss of power
    Newbie been reading old posts with interest. Not very mechanically minded but will try to give as much info so someone can help!
    I bought a December 1998 A4 2.5 tdi Quattro Avant Automatic in March this year with only 81,000 1 previous owner and full Audi History from a trader of his drive. Seemed a very genuine car (smell of oil noted on old mot)
    Had the car serviced buy a local independent (merc specialist previously used) used for 5 trouble free months (7,000 miles).
    Then oil leak started. garage investigated and found hole drilled in rocker cover (behind oil cap). Replaced cover & gasket also crank case breather.
    Oil leak remained, second investigation removed expansion tank and vac pump. Replaced seals in vac pump and refitted. At the same time replaced exhaust inlet manifold gasket.
    Oil leak now seems to be curred but loss of power. Won't pass 95 ish. Revs don't drop but up hill it will slow down to 50.
    Sorry for the ramble but guess more info is better than less any ideas?
    It's now on 95,000 miles so 14,000 in 9 months in a 13 year old car it's bad. Apart from above it's been serviced and put a set of Michelins when I bought it. Now on Michelin Alpins with a set of steel rims for winter just need some cold weather.
    Also 2 other b5s in the family bought this year both 2.8 auto Quattro avants 2000 one with 85,000 the othe only 30,000. Both run like a dream!!
    Thanks in advance. Jon
    Jul 2007
    London
    1,571
    Post Thanks / Like
    It needs a diagnostic scan first as it could be a number of things: MAF, turbo clogged, boost control solenoid,etc.
    FOR SALE:
    Dec 2011
    Post Thanks / Like
    Booked in garage on Tuesday, will post reply then
  1. 2007 a3 quattro 170 tdi high idle loss of power help needed
    By gixer600 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd May 2011, 15:37
  2. loss of power 2.5 tdi quattro
    By s4mmie in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th February 2011, 18:00
  3. 170 TDi Quattro power loss and economy
    By Mini-mad-matt in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 6th October 2010, 21:15
  4. 2.0 TDI Loss of power
    By cooky19 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th March 2010, 11:59
  5. A3 2.0 TDI 170HP Quattro - 230km'h and strange power loss issue
    By ronald_adi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th July 2009, 13:17
