Sky InsuranceAMD Technik
Results 1 to 7 of 7
    jcb
    Sep 2005
    uk
    3,784
    Post Thanks / Like
    calling OEM turbo experts
    what is the largest OEM longitudinal KKK turbo?
    RS6?
    Ko4?
    what are the options for picking up crapped out turbos and cobbling together a larger hybrid?
    there is a chance i have a soon to be dead turbo having ingested a spark plug electrode and now sounding like a constipated duck!
    I have a few people locally that have dead turbos and some with cracked housings, if I can pick up some cheap ones, find one with a decent CHRA and replace some bearings, seals etc.
    how tricky would it be to produce something that would be larger than stock for flow and A/R ?
    I have stripped a few turbos but in theory if you pull turbines and compressors off the shafts and match them to housings I am thinking it wouldnt be too tricky to match a better flowing turbine housing from RS6 or similar and mate it with a bigger compressor housing .
    I can afford to play around with compressor housings from transverse engines and mod an inlet mani, cant afford to be messing with mani and downpipes.....
    I never managed to sell my Eurodyne mapped ECU and 630cc file/injectors so I am thinking if I can pull together something that will sustain a bit more boost and not breach a late 200-300bhp I will get away with running stock rods and slap it on the downpipe I have.
    dont mind swallowing a bit of cost but this is a budget option!
    "Stick a V8 in it!"
    Cleveleys, Lancashire
    11,839
    Post Thanks / Like
    Theres a thread over on the 8L section detailing exactly this. "Hybrid Turbocharger Build" i think its called.
    Basically exactly as you've said, you can pillage larger parts and cobble them together, and this is more or less exactly what the hybrid builders do. The turbine housing will need machined out to take the larger turbine, as the transverse/RS6 ones wont bolt onto your existing manifold, and the compressor will also either need machined out or replaced with a different item depending what parts you choose.
    I've been considering putting together a hybrid using an S3 turbine and compressor wheel, machined out A4 turbine housing, and S3 compressor housing and backplate.
    Alternatively, Mark (Byzan_A4) has just removed a hybrid from his car, so perhaps he'd be willing to sell you that for a bolt in minimal hassle solution?
    For Sale: Breaking B5 A4 - Check my eBay page!
    Wanted: Facelift A4 Front Bumper with Headlight Washers.
    2000 A4 1.8T Sport Quattro Avant, Beere Pearl, TT Carriers and B6 312mm Disks.
    2000 A4 1.8T Sport Quattro Saloon, Black-ish, Now Running!
    1997 S4 - PPC £999 Challenge Track Car Build starting soon!
    Audi V8 powered Land Rover Defender build in progress.
    Bradderz_1988's Avatar
    The only way is ..... German !
    Aug 2010
    Greater Manchester
    1,065
    Post Thanks / Like
    Why not just get a k04 and a rs4 compressor housing and do something similar to the loba/frankenturbo hybrid if your committed to it ??
    1999 Audi A4 1.8T Quattro Sport - Volcano Black - Frankenturbo'd
    Wanted - S4 Skirt/Wing trims, S4 side skirt brackets.
    jcb
    Sep 2005
    uk
    3,784
    Post Thanks / Like
    Well that is what I am thinking
    Frankenturbo is $1000 and from what I can see I am only going to get another 40-60bhp, seems a bit pricey bang per buck.
    I can get a warrantied recon Ko4 for less than £200
    I am just not up on the various specs of the turbos. I know the KO4 is on the TT/S3/LCR/RS6 but its getting the right frame for the longi platform
    TBH machining is not that expensive
    my next issue is the mapped ECU I have is for 630cc injectors and a 4" MAF that can take anything up to a 3071 sized turbo.
    If I ran a "Ko4+" sized unit on that map I reckon on a conservative estimate I would only be pushing the injectors to 50-60+% duty on moderate boost. being ariflow based it can adapt to any turbo so I am not sure that is a major issue, but would certainly keep my costs down!
    I also have an option of a T3/T4 unit going for super cheap, I just dont want to be pissing around using a fabricator for a custom Downpipe as that will get pricey.
    bez101's Avatar
    Jul 2008
    3,415
    Post Thanks / Like
    where can you get K04 with warranty at £200 ?
    jcb
    Sep 2005
    uk
    3,784
    Post Thanks / Like
    eBay - The UK's Online Marketplace
    could be crap, I dont know, but on the basis I would be using it for parts....
    Der_Techniker's Avatar
    Foursprung Duck Technique
    Oct 2010
    Coventry, West Midlands
    991
    Post Thanks / Like
    Their a bit poor I'm lead to believe. Bad quality materials and not well balanced so vibrate themselves to bits rather quickly.
    2000 Silver Audi A4 1.8T Sport, With added Carbon Goodness
    "Arguing with an engineer is a lot like wrestling in the mud with a pig. After a few hours, you realize that he likes it."
  1. Calling S3 Seat Experts - Movement Problem with Pics, Advice Please?
    By fran-s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4 Weeks Ago, 21:11
  2. calling all detaling experts
    By nally in forum Detailing
    Last Post: 20th November 2011, 20:17
  3. Temp sender. OEM or None OEM.........
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th April 2011, 19:32
  4. OEM S3 Turbo Part Code
    By Jacko4130 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th March 2011, 20:40
  5. calling all turbo suppliers jbs bds ect ect
    By bansheeboyo in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd January 2009, 13:08
