Revo TechnikAdrian S Flux
    Jun 2011
    21
    Post Thanks / Like
    Bulb Light Error
    Hi all,
    had the bulb error showon the DIS then an annoying bleep all the way back on a 3 hour drive ,
    I have checked every bulb and can't find any not working ,it is now errtic when it starts out showing ok then sometimes
    starts flashing error again ,
    has any one any ideas ,thanks in advance
    "Stick a V8 in it!"
    Cleveleys, Lancashire
    11,839
    Post Thanks / Like
    What does it look like? It only monitors a few bulbs, mainly headlights on the front and brakelights on the rear.
    Brakelights symbol looks different to the headlight one though.
    For Sale: Breaking B5 A4 - Check my eBay page!
    Wanted: Facelift A4 Front Bumper with Headlight Washers.
    2000 A4 1.8T Sport Quattro Avant, Beere Pearl, TT Carriers and B6 312mm Disks.
    2000 A4 1.8T Sport Quattro Saloon, Black-ish, Now Running!
    1997 S4 - PPC £999 Challenge Track Car Build starting soon!
    Audi V8 powered Land Rover Defender build in progress.
    Jun 2011
    21
    Post Thanks / Like
    Damn ,I'll have a look and post a picture ,thanks
    Jan 2011
    Aberdeenshire
    205
    Post Thanks / Like
    Not wanting to worry you, but that is what I had starting to happen with my wife's car here, DIS dead However, all this may have been caused by a not great battery!
    One of the clues was it would be a little slow to start, then the voltmeter would take an age to come up. Once up to 14V (ish) it was fine.
    If she put on heavy electrics before it was at 14V (alternator online) the voltage would drop off. At some low voltage point she had the bulb warning go off.
    Of course, it could also be the bulb monitoring unit in the drivers footwell under the dash.
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
  1. HOWTO CHANGE REVERSING LIGHT BULB S LINE 8P & WHICH BULB???
    By niffty in forum General Technical / How To
    Last Post: 29th April 2010, 16:24
  2. Intermittent bulb failure error
    By Wrath in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd November 2009, 18:52
  3. Bulb error after HID attempt
    By Xmay4444 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th August 2009, 21:15
  4. bulb error on DIS - Help Required
    By Speedo in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th March 2007, 22:11
