The only way is ..... German !
If its over revving it could be the turbo seals have gone and it's throwing oil into the intake also would give you a big cloud of smoke out the exhaust but also the egr can cause it to smoke more than it should.
If I was in your position id be blanking off the egr both sides with a coke can cut to block both sides of the egr and sandwiched between the fixingsand giving a quick run to see what improvements this does.
1999 Audi A4 1.8T Quattro Sport - Volcano Black - Frankenturbo'd
Wanted - S4 Skirt/Wing trims, S4 side skirt brackets.
