Can anyone help wondering if i could fit a set of 18 inch x 9 1/2 et44 amg wheels to my audi a4 b5 quattro if so what tyre size should i use
Any help would be greatly appreciated thanks.
rezulteo liked this post
It all depends on what tyres will fit your car. This is specified by the manufacturer. I can tell you more if you let me know the engine details (Capacity etc...)![]()
Tyre news, advice, tests and comparisons on http://www.rezulteo-tyres.co.uk
Tony-B5 liked this post
2000 Silver Audi A4 1.8T Sport, With added Carbon Goodness
www.facebook.com/arrkonphoto - give us a like
"Arguing with an engineer is a lot like wrestling in the mud with a pig. After a few hours, you realize that he likes it."
I tried 8.5" audi a8 fat5 alloys with 234/40/18 tyres and that was rubbing onto the rear uprights. The ET of the wheels is 43 and had no issues up front. You could probably roll the arches and fit a 5-10mm spacer in there and narrow tyres. I have rs4 style alloys 8" wide with 225/40/18 and have no issues either with ET35 or 45 !
FOR SALE:
But these are 9.5" so will require big camber and big tyre stretch to squeeze in the arches!
Laser Red 98 A4 1.8T - B7 A4 17" wheels, Weitec GTN coilovers, Front strut brace, Custom rear dual strutbrace, Custom rear floor brace, RS4 front lower subrame brace, Neuspeed rear Antiroll bar, Shortshift with lever extension, Silicone TIP, Jetex cone, Forge 007p, Jetex 2.5" catback exhaust, THS 3" Decat, Custom downpipe, 312mm Front brakes, RS4 Engine Mounts, RS4 Snub mount, Audi 80 TDI solid flywheel, Audi S2 3B clutch kit, Rtech mapped
199bhp 221ft-lbs
Ive got Porsche cayenne turbo wheels at the moment 18x8 et 57 with 235/40/18 no rubbing but it is a very tight fit but does not rub.
I have had 245/40/18's on 8.5" rims and rolled arches
now run 235/40
My ET is 24 so 20mm outboard of yours. You may have to play around with spacers to clear uprights on ET45 9.5s
its not just the ET its the combo of ET and width. suspect you will have to go to ET35 to clear rear uprights, fronts have more room
find tyres with angled tread pattern to sidewall joins (PS2's were always good) and it will help arch/upright clearance
Using spacers (approx. 10mm will do the trick) and 225/40/18 tyres and it will be ok. I'm currently running 9"x18" wheels with et37 front and et34 rear with 235/40/18 tyres on. Because running pretty downlow there are some rubbing appearing in my case.![]()
Slow and smoking - A4 2.5TDi+ 204kw/570nm
As promised here is a page that will help you find the tyre sizes that fit your vehicle, specified by the manufacturer :
A4-Quattro tyres. All Audi A4-Quattro tyres
I hope this helps you out![]()
No pics sorry mate but have just tried them on the car without tyres looks like i'm gonna have to fit 5mm spacers as i dont wont them to poke out to much past the arches & stretched tyres are a must hope they dont rub on full lock![]()
