JBSGNJ
    Dec 2011
    Chichester
    Post Thanks / Like
    Allard 'Powerpipe' EGR delete kit Vs EGR blanking plates?
    Hello all. Newbie with Audi TDi's would like your views please.
    Current car is a 1998 A4 Avant 1.9TDi 110. Suffers from the loss of power/limp mode after hitting @2600 rpm which rectifies itself if I switch off-switch on. EGR has been replaced but problem still exisits & area around the replacement EGR is soot marked. Have had a fault code done & the garage tells me its a 'manifold pressure' issue.
    As the EGR is a virtually useless piece of kit, I've read on here that EGR Blanking Plates are possibly the way to go. I've also looked at the Allard 'power pipe' option.
    Blanking plates: eBay - The UK's Online Marketplace
    Allard: eBay - The UK's Online Marketplace
    Q1: If I use the blanking plates, do I remove the whole EGR assembly & crinkly pipe & place the blanks over the bottom exhaust manifold hole & the top inlet manifold hole? - & block off the sensor pipe from the EGR? If so, does it work?
    Q2: Allard. When I enquired about the Allard kit the man said blank plates were ok but didnt remove the 'flapper' which caused air restriction. Has anyone used this kit on a similar car? & is is worth the £53?
    Paul
    Dec 2011
    Chichester
    Post Thanks / Like
    Answered my own question - Allard dont do a kit for the AFN engine code so I've sent it back as I spotted it wasnt correct as soon as I unwrapped it.
    However, trying to get a refund is proving a little difficult.......................
  1. Allard EGR Delete kit?
    By sinic in forum Diesel forum
    Last Post: 18th April 2012, 13:37
  2. EGR Blanking Plates
    By Sammo in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th December 2011, 03:25
  3. Performance probs after fitting EGR blanking plates
    By tuffguy in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 14th September 2011, 16:09
  4. EGR blanking plates
    By ScottB5 in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st July 2011, 09:01
  5. Allard EGR delete kit
    By TDiSPORTA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th June 2010, 21:55
