Badger5DNA Tuning
Thread: wiper help?
    Apr 2011
    13
    Post Thanks / Like
    wiper help?
    hi all. i'm having a nightmare with the wipers on my '99 2.5 a4 avant. On friday, went to switch my wipers on and nothing happened. turned them off and on again and after 20 seconds started working. This happened twice then 3 miles from home, stopped and not worked since. After looking through the forum, found out about the linkage sticking so stripped the linkage/motor out, bench tested and works fine with 12v connected to it. just been checking the fuse and you can hear the relay clicking when taking the fuse out and in but still no wipers work on any settings!!!!
    any help or ideas would be greatly appreciated...
    cheers
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,611
    Post Thanks / Like
    So did you actually check and repair linkage for seizing first?
    And when you re-tested, did you assemble the motor back to linkage or just check the motor itself?
    Project RS28 build
  1. o/s wiper arm not forcing wiper onto windscreen
    By markie A3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd March 2011, 22:53
  2. Wiper arms and wiper blades
    By M4KTT in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th September 2009, 11:55
  3. Wiper - patchy contact, loose wiper arm?
    By SamDude in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st June 2007, 20:33
  4. CHIPPED MY CAR BUT SNAPPED WIPER SPINDLE GETTING WIPER OFF
    By daztenerife in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th June 2005, 23:28
  5. New A3 Wiper Motor Replaced, Is the wiper too high
    By Rolex1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th February 2004, 20:37
