JBSDPM
Results 1 to 22 of 22
    B5QUAT's Avatar
    Apr 2011
    Manchester
    206
    Post Thanks / Like
    1.8T to S4 clutch upgrade questions
    Hi,
    My clutch has started slipping (probably down to age and the 20psi going through it) so I feel it's time to upgrade to the B5 S4 clutch in readiness for the upcoming GT28 next year.
    Seen this flywheel kit which allows upgrade to the S4 clutch:
    Audi B5 A4 Quattro 1.8T > Drivetrain > Clutch > ES#12084 ECS RA4 Steel Flywheel Kit - ECS212321B5KT
    One I got this, would all that I need be the S4 clutch kit or are there other parts required?
    Where's the best place to get a B5 S4 clutch kit from that will be reliable? Any ideas?
    Ming Blue 1999 1.8TQS. Mods so far: full non res Milltek, decat pipe, Weitec Ultra GT suspension, Meyle front arm kit, 18" BBS LM reps, interior LED upgrade, Advanced tuning chip (20psi), Pipercross filter. Planned mods: FMIC, B6 S4 brake setup, RS4 Clutch, ECS flywheel, GT28RS conversion and custom remap.
    jamie226bhp's Avatar
    Aug 2009
    438
    Post Thanks / Like
    Gsf or euros I'd have thought
    2000 A4 1.8 tqs scroll sp51, ths decat, milltek cat back with rs4 backbox, remap
    VW/Audi parts advisor
    May 2010
    Bedford
    1,220
    Post Thanks / Like
    Or just buy the complete kit from ECS if you`re going to get the flywheel from them?
    If you buy it seperate over here then the RS4 clutch is barely any different in cost so you might aswell go the whole hog and future proof it.
    Laser Red 98 A4 1.8T - B7 A4 17" wheels, Weitec GTN coilovers, Front strut brace, Custom rear dual strutbrace, Custom rear floor brace, RS4 front lower subrame brace, Neuspeed rear Antiroll bar, Shortshift with lever extension, Silicone TIP, Jetex cone, Forge 007p, Jetex 2.5" catback exhaust, THS 3" Decat, Custom downpipe, 312mm Front brakes, RS4 Engine Mounts, RS4 Snub mount, Audi 80 TDI solid flywheel, Audi S2 3B clutch kit, Rtech mapped
    199bhp 221ft-lbs
    Mar 2011
    suffolk
    250
    Post Thanks / Like
    work at euros clutch kit part no 641441570- 179+ vat retail but can get 25% on website at mo
    Bradderz_1988's Avatar
    The only way is ..... German !
    Aug 2010
    Greater Manchester
    1,065
    Post Thanks / Like
    Or you could fit this mate 110756040178
    If just done the 1Z conversion with the ata/agk pressure plate and V8 friction disc all for £280 and I can honestly say its transformed the way the car puts the power down as the clutch was totally knackered and I hated the DM flywheel !!
    1999 Audi A4 1.8T Quattro Sport - Volcano Black - Frankenturbo'd
    Wanted - S4 Skirt/Wing trims, S4 side skirt brackets.
    B5QUAT's Avatar
    Apr 2011
    Manchester
    206
    Post Thanks / Like
    Cheers for the replies. Think I'll take Jason's advice and go RS4, make it futureproof.
    Cheers for the link Bradderz.
    B5QUAT's Avatar
    Apr 2011
    Manchester
    206
    Post Thanks / Like
    Quote Originally Posted by Bradderz_1988 View Post
    What bits do you need for this conversion and what vehicles are they from? Sounds good value for money.
    Aug 2010
    Greater Manchester
    1,065
    Post Thanks / Like
    You need the 1z flywheel fitted to some Audi 80 tdi and 2.0 and some early A4's an S2 clutch which is fitted with a SM flywheel or either the ata/agk pressure from a VW LT van and V8 friction disc.
  10. Thanks B5QUAT thanked for this post
  11. #9
    "Stick a V8 in it!"
    Cleveleys, Lancashire
    11,839
    Post Thanks / Like
    As Bradderz says, you need:
    Audi "1Z" flywheel. Its fitted to most 1.8/1.9/2.0 4 cylinder Audi 80/100 models including the coupes. Expect to pay around £30 used, or £120ish new.
    then either
    complete 3B engined S2 clutch kit
    or
    Clutch pressure plate from a VW LT Van with an ATA or AGK engine
    240mm Friction plate from more or less any longitudinal Audi, i used a B6 S4 V8 one as it was on ebay cheap.
    release bearing (standard A4 one will work)
    I went with the second option, as i found the pressure plate and friction plate on ebay for around £110 all in.
    Then you need to have the flywheel redrilled to accept the larger pressure plate by a competent machine shop, and preferably balanced afterwards (i didnt have mine balanced though, and it seems fine) This cost me 90quid iirc.
    For Sale: Breaking B5 A4 - Check my eBay page!
    Wanted: Facelift A4 Front Bumper with Headlight Washers.
    2000 A4 1.8T Sport Quattro Avant, Beere Pearl, TT Carriers and B6 312mm Disks.
    2000 A4 1.8T Sport Quattro Saloon, Black-ish, Now Running!
    1997 S4 - PPC £999 Challenge Track Car Build starting soon!
    Audi V8 powered Land Rover Defender build in progress.
  12. Thanks B5QUAT thanked for this post
  13. #10
    Aug 2010
    Greater Manchester
    1,065
    Post Thanks / Like
    They still have the friction plate on eBay that i used at the mo but I think I have purchased there last ATA/AGK pressure plate they had in stock, I priced both of these from TPS to see how much they where and they where around £98 each (remanufactured) for them.
  14. #11
    Mar 2011
    suffolk
    250
    Post Thanks / Like
    im just about to replace my clutch but know ive seen this thred its got me thimking any one know the o.e number on the 1z flywheel
    as can get the s2 clutch for 120 brand new (sachs) if my flywheels gone im going to be up for this conersion.
    also i take it this would work for the 1.8t fwd models as well as the quattro?
  15. #12
    Der_Techniker's Avatar
    Foursprung Duck Technique
    Oct 2010
    Coventry, West Midlands
    991
    Post Thanks / Like
    yup indeed it would.
    2000 Silver Audi A4 1.8T Sport, With added Carbon Goodness
    "Arguing with an engineer is a lot like wrestling in the mud with a pig. After a few hours, you realize that he likes it."
  16. #13
    May 2010
    Bedford
    1,220
    Post Thanks / Like
    Yep as i have a FWD and have done it. OEM number is 026105269L (x for exchange)
    199bhp 221ft-lbs
  17. #14
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    tangerine, make sure the clutch you've found is from a 3B engined S2. Most S2's use a dual mass and "pot" style flywheel, only the 3B has the single mass flat unit.
  18. #15
    Mar 2011
    suffolk
    250
    Post Thanks / Like
    it should be mate done it at work ( eurous) listed for 2.2 20v turbo quatro (3b) sachs part number 3000 455 001
  19. #16
    Mar 2011
    suffolk
    250
    Post Thanks / Like
    Quote Originally Posted by Jason.s View Post
    how much is a new one jason because struggling to find any used?
  20. #17
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    That sachs part number isnt correct. Its for the older 016 gearbox and has a different friction disk with the thinner 24 spline input shaft rather than the thicker 23spline shaft your box has.
    The pressure plate in that kit is correct though.
    Sachs dont do a kit for the 3B S2, they only sell the pressure plate and friction plate as seperate components.
    Friction plate is 1862 625 001
    Pressure plate is 3082 919 001
    You can use that pressure plate with one of the V8 disks from ebay if you want though.
  21. #18
    May 2010
    Bedford
    1,220
    Post Thanks / Like
    Inc vat with the surcharge which you`ll have to pay its £155.15 unless your local VW/Audi dealer will give you discount for working at Euros.
    Is it not one you can cross refer over from the genuine part number to your system and find a non gen one?
    199bhp 221ft-lbs
  22. #19
    Mar 2011
    suffolk
    250
    Post Thanks / Like
    okay so if i got that
    sachs pressure plate (3082919001)
    flywheel from jason.s
    and v8 disk from ebay
    then use the standard release bearing?
    do you have ebay link to disk aragon
    cheers for all your help mate
  23. #20
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
  24. #21
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    There are plenty Audi 80's breaking on ebay, surely you can find a flywheel from one of them!
  25. #22
    Aug 2010
    Greater Manchester
    1,065
    Post Thanks / Like
    Why not try this thread for phone numbers to source one.
    Audi/VW Breakers/scrappers
  1. Clutch questions again .
    By cawsey20 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th May 2010, 00:51
  2. S3 clutch questions
    By jcb in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th September 2008, 19:04
  3. Clutch questions
    By K7ERG in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st December 2007, 08:02
  4. K04 Upgrade questions
    By Beerzo in forum Tuning
    Last Post: 2nd March 2006, 13:16
  5. Newbie Upgrade Questions
    By QuickSilver2 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd December 2004, 17:23
