Which rear discs 1.8T FWD??
Oranoco
HertFORDshire
Website
www.passionford.com
Need to do my rear brakes on the old tank and popped onto www.nextdaybrakes.com to sort some nice Brembos out. Unfortunately it lists 2 discs for my car and the only difference I can see between the 2 is one says "wet" and is twice the price.
Don't want to order the wrong discs so any help appreciated.
I see what you mean after looking at the listings..wet weather discs being more expensive. After a google search of Brembo wet weather discs all the links suggest they`re grooved or drilled. So that`ll be your answer it seems.
When you look at how pathetic the rear calipers are and experience how bad the handbrake is on these cars I'd buy a set of Pagids.
Yeh exactly, £70 with Audis mental markups added on.
I just dont buy into fancy disks, its a lump of cast steel, so long as its made by a reasonably well known company it'll be fine.
You can buy Mintex or similar disks for around £30 a pair, and that company are wanting that for a single disk!
Actually i was looking at a Passat disc forgetting they were different. £43 per disc sorry :p
discs can be as cheap as you like, as aragorn said.
just put decent pads on. pagids or similar...
7
473
613
