EM TuningMonster Motorsport
Results 1 to 13 of 13
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,866
    Thermostat where is it located on 1.8T. ??
    Basically as title as I think I've got the old thermostat stuck open fault as the temp gauge has a mind off it's own and my mpg has gone through the floor. And also get the 16500 DTC.
    A good write up or pic would be great.
    Cheers.
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    Follow the bottom rad hose, it goes to a little plastic elbow, and the stat is under there.
    I find the best way to change it, is to first remove the hose from the elbow (i replaced the constant tension clamp with a jubilee as its less faff) then remove the elbow and stat.
    You then need to sort of balance the new stat and seal on the elbow, manoever it into position round a bit of block casting that sticks out, then bolt the housing up. Then refit the hose.
    Its much easier to refit it without the hose attached, hence removing it.
    TD5 Land Rover Defender build
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,828
    under the inlet manifold,but above the oil housing.
    I believe two screws holding it to the block.be sure to get a new rubber gasket aswell
    "Stick a V8 in it!"
    14,900
    Not on an 058 block.
    On an 058 like the AJL Bradderz has, it has an external water pump and the stats mounted under that, right down the bottom beside the PAS pump.
    Aug 2010
    2,866
    Cheers guys thought it might of been on back of the block as I'm doing the clutch conversion this weekend (if I get round to it) so was seeing of I could of done it a bit easier with the box out.
    "Stick a V8 in it!"
    14,900
    Its not on the back of the block its on the waterpump housing.
    Drop the undertray off and look up on the passenger side, its right there.
    You got access to a lift to do the box?
    Aug 2010
    2,866
    Yes got access to do the box as I work at Citroen so no problems with access or tools.
    I think I may now where it is is it held to the block with 2 10mm bolts just opposite/behind the water pump housing ???
    "Stick a V8 in it!"
    14,900
    It doesnt attach to the block at all, it attaches to the underside of the waterpump housing itself. Sort of just behind the PAS pump.
    Aug 2010
    2,866
    Kk I'm sure il find it lol
    "Stick a V8 in it!"
    14,900
    just follow the hose, goes right to it.
    Aug 2010
    2,866
    Is this the puppy on the bottom ???
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,354
    inside that black plastic housing
    Aug 2010
    2,866
    Cheers mate
  1. 1.8T AGU engine: Where's the ECT located and...
    By luckymacy in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th December 2009, 16:23
  2. So where is the MAP sensor located?
    By dieselfitter251 in forum Diesel forum
    Last Post: 15th February 2009, 17:57
  3. Where is the engine number located on a S4 B5 ??
    By AdamS4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th July 2007, 13:02
  4. Where is the 710 located exactly?
    By jazzyc in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th July 2007, 20:31
  5. Located some S4 side skirts
    By ad3crk in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd September 2006, 21:32
