EM TuningBadger5
    Nov 2011
    1996 A4 Clutch Problems !!!
    Hi everybody ! Just joined this site + thought I'd find out everybody's opinions on clutch problems I'm having. Clutch pedal free travel has increased (engaging point is lower to floor) and difficult to get gears. Also whirring noise when clutch pedal depressed.
    Slave cylinder was replaced 3 mths ago and system bled. Any ideas as to how far down clutch should engage and what's causing this ?
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,136
    What engine do you have ??
    Your only way to really find out is to whiz the gearbox out !!
    Also dual mass flywheels are problems to start of with.
    Nov 2011
    Model is basic 4 door with 1.8 engine (code ADR).
    Aug 2010
    3,136
    Whirring noise could be the release bearing.
    When the clutch is pressed is there any judder/vibration through the pedal/car ??
    I've seen this sort of fault many of times at work on the Citroen C1 were the clutch pressure plate breaks of one of the plate retaining spring/fingers
    Nov 2011
    No judder/vibration through the pedal/car when the clutch is pressed. I also think whirring noise is release bearing so I guess it's probably going to be gearbox out and complete clutch replacement job ! Although I'm also wondering whether master slave cylinder has anything to do with it ?
  1. Power problems with 1996 A4 110hp TDI AFN
    By ollied1981 in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th November 2006, 17:28
  2. Common Problems with 1996-2000 A4'S
    By hpolanco in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th November 2006, 22:48
  3. Power problems with 1996 A4 110hp TDI AFN
    By ollied1981 in forum Diesel forum
    Last Post: 8th November 2006, 13:52
  4. 1996 Audi 80 Cabriolet - Roof Problems
    By stellarborne in forum Classic Audi Forum
    Last Post: 8th July 2006, 20:30
  5. Possible worn clutch? A4 1.8T 1996 - strange .
    By imported_bpascua in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th November 2004, 16:15
