EM TuningChris Nott
    Jun 2011
    73
    Rear wheel sqeak B5 A4/S4 1.8T Quattro Sport 1999
    I was out in the quattro last night, on leaving the petrol station and driving down the road a few yards, a loud sqeaking or sqealing started from what sounded like the left rear wheel, after about another few yards it stopped and was quiet from then on, I am hoping it was maybe a stray stone that got trapped in the brake disc guard, as it did sound very "tinny" keeping a close eye on things at the moment - does anyone have any suggestions if this could be a sign of either a wheel bearing going or the ABS sensor ? No fault code showed during the noise on the DIS system.
    Jul 2007
    770
    Have you looked at the pads?
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,135
    Handbrake wasn't on slightly was it ??
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    Possibly the calliper slightly stuck on?
    2000 1.8t quattro Sport totally standard (ish)
    Jun 2011
    73
    Brake pads seem fine - approx. 6 or 7 mm of thickness, handbrake was fully off as far as I can remember, caliper could have been slightly stuck on, but the noise has not happened again yet !!
  1. 1999 1.8 T Sport Quattro front fogs?
    By daver555 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th March 2008, 12:54
  2. Chipping an Audi 1.8T A4 Quattro Sport 1999
    By netwave in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th August 2006, 15:02
  3. Does a TT Engine Fit in a 1999 A4 Quattro Sport?
    By gc48067 in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th August 2004, 16:29
