Volks AutosAH Fabrications
    Nov 2011
    audi a4 1.9tdi starts then stops immediately
    hey every1 i hope im in right topic ... i bought a audi 1.9tdi estate yesterday and having a bit of problem , when i viewed car it was already warmed up from him driving half way to meet me but since getting home with it , i have found quite a bad problem wich is it starts up and then dies instantly it may take me 7 times before it finally starts then runs evenwhen car is warm sometimes. there is a sparkline alarm and imobilizer on the car but light goes out when imobilizer is pushed in so dont think it that , any help much appreciated.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,871
    Glowplugs or egr valve ??
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,904
    Sounds more like the factory immo kicking in?
    Does a yellow key symbol flash on the dashboard when it cuts out?
    TD5 Land Rover Defender build
    Nov 2011
    all what comes up on display were miles ive done so far is " ins 2 " ?
    Jan 2011
    Aberdeenshire
    628
    That's the service that's due - an Inspection 2, the handbook will tell you what needs to be done on your car for this.
    You'll need to get it scanned to see what codes you have, if any.
    If you read the forum, you will see a lot of talk of VagCom/VCDS. You will need this (or similar) to diagnose faults on your Audi.
    As it is a bit expensive, you could look here ***VCDS Users Map*** to see if there is anybody near you to exchange beer tokens for scans.
    1999 A4 B5 1.9 TDi FWD Saloon, Green
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine)
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,355
    Put the key in and turn the ignition on and a yellow symbol with a car and a key underneath should inside the revcounter along with the other warning lights.
    It should then go out and stay out. If it stays on or starts flashing, the car will start then cut out. If it doesnt come on at all then the same applies.
    What age is your car?
  1. Replies: 3
    Last Post: 20th August 2011, 22:12
  2. A3 S3 starts but stops
    By tomgunn in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2009, 11:36
  3. 1.8T Rev Heads Report here immediately!!!
    By J7USS in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th July 2007, 13:41
  4. A8 Engine starts, runs for 2 seconds then stops
    By tallmat in forum A8/S8 forum
    Last Post: 29th November 2004, 11:55
