AH FabricationsChris Nott
Results 1 to 8 of 8
    Oct 2010
    Ayrshire Scotland
    79
    gooosed alternator ?
    Hi guys.I only know basic mechanical knowledge so wondering if anybody can give me some pointers, this morning I realised that my battery light stayed illuminated on my dash. immediately i thought it was my alternator, so i drove to work with no music , blowers, lights ect, occasionally the light would go off and flicker then illuminate again. mainly staying on, checked all the belts ect everything seems ok, revved engine while full beam was on, no dimming of lights ect, no erratic noises coming or have been from alternator. everything seems normal execpt the light on ! kept engine going and disconnected battery and engine dies ( i know bad practice). any ideas (Will the car will be capable of doing a 12 mile trip tomorrow ? as i cant get doing anything untill friday) thanks for any help!
    Nov 2011
    7
    try to get hold of a multimeter and take a reading across the battery with the car off and the car running. with it off it should be about 12 and with it running around 14 ish. and the reading with it running shouldn't fluctuate really, could be a bad regulater on the alternator
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    What's the voltmeter on the dash reading ?
    Oct 2010
    Ayrshire Scotland
    79
    mines is a 2000 1.9 (Non SE) doesn't have a voltmeter
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,390
    I thaught they all had a volt meter in the bottom right corner of the instrument cluster?
    Ideally you want to check the voltage with the engine running as mentioned above, using a multimeter.
    You might manage a 12 mile journey, but i'd be putting the battery on charge tonight to ensure its full for tomorrow, rather than starting out with a half discharged battery!
    TD5 Land Rover Defender build
    Oct 2010
    Ayrshire Scotland
    79
    my last a4 was a 98 preface-lift - had the cluster voltmeter,oil temp and also the trip comp ect. mines is face-lift with none of them, just the OK symbols ect. Ok cheers for the help !
    Nov 2011
    7
    did you do a volt test?
    Oct 2010
    Ayrshire Scotland
    79
    it was goosed, was only getting a reading from the battery, was hoping it was a bad earth or something. new alternator fitted £138
  1. '01 2.5 Q alternator help please?!
    By Littlechat in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st October 2009, 20:06
  2. Alternator Gone
    By Defratos in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd July 2009, 00:42
  3. Alternator
    By otis_b in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th September 2007, 13:30
  4. Where Is The Alternator?
    By Biggles in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th May 2007, 16:40
  5. S3 Alternator
    By HmanS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd March 2007, 11:16
