JMB RetrofitsAH Fabrications
Results 1 to 22 of 22
Thread: Clutch advice
    jamie226bhp's Avatar
    Aug 2009
    464
    Clutch advice
    My clutch had started to slip on my 1.8 tqs does anyone know any good replacements at a reasonable cost it's been tuned and is running spprox 250+ ftlb and I haven't got the time to source the bits for the single mass conversion are there any uk options or is it a 034 kit, recommendations and people own experiences would be of great help
    2000 A4 1.8 tqs scroll sp51, ths decat, milltek cat back with rs4 backbox, remap
    Aug 2009
    464
    Any one know anything about the ones on eBay that come with the solid flywheel ad part of the kit
    I.E
    http://item.mobileweb.ebay.co.uk/vie...id=90944778762
    Jun 2010
    Quote Originally Posted by jamie226bhp View Post
    It's slipping because the clutch slips against the flywheel. This is not good for the clutch. you can take it to a Audi repair shops nearest you, they have some replacement parts. It can be simple or complicated. It is often possible to simply remove the plate when the transmission fluid drain and adjust from there. Some are a little harder.
    Jun 2010
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,135
    I was thinking of going for one of these but wanted to go 240mm where as they are 228mm iirc.
    I've got a used 1z flywheel (with bolts) for £45, new bearing and clutch bolts £29.
    And I'm going to get the clutch and machining done which will be about £180 which is cheaper than any valeo conversion or the ridiculous over priced US items.
    Or if you can haggle and don't mind shipping costs, why not try these
    250931914104
    150635641662
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    IMO theres no point messing around with "performance" 228mm clutches.
    Your options looks something like this:
    A) Bolt on a standard one, but tbh if your existing clutch is slipping badly the flywheel is probably ruined and needs replacing which means your spending probably the best part of 400quid on a standard setup.
    B) Buy an off-the-shelf single mass conversion like the ebay link or the more common valeo part. Unfortunately these use bespoke clutches and if you buy it and find out its not up to the job on your tuned engine, finding an upgraded part may well be impossible.
    C) buy an off the shelf 240mm upgrade kit. Much more sensible than A/B but they're extremely expensive. You're looking at 250-300 for the flywheel itself (which ofcourse is similar to a new standard DMF) then the best part of 200quid for an RS4 clutch. It is then a hugely capable setup.
    D) Piece together your own 240mm conversion based on the 1z Flywheel. I paid roughly £30 for the flywheel itself, £90 for the machining work, and managed to get the coverplate and friction disk for £95 after some lucky ebay shopping.
    TD5 Land Rover Defender build
    May 2010
    Bedford
    2,877
    The F1 setups are actually pretty good for the money to be honest. Quite popular in the Honda world too.
    Cheapest option you`re going to get is the 1Z fly and source an S2 3B clutch and be done with or use the LT cover plate and v8 disc.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    Aug 2009
    464
    What's up with the 228mm setup as surely if the pressure plate is able to cope with the torque it will be fine and I'm never gonna be putting out more than 300 lbft without the need for rods
    May 2010
    Bedford
    2,877
    Just never going to be as good as the 240mm set up. Its like saying why not stick with the 288mm front discs instead of 312mm when you arent going to be driving any faster. Its always better and puts less strain on components when things are bigger
    "Stick a V8 in it!"
    15,370
    Its really upto you at the end of the day. I went 240mm because i wanted to be using factory parts with factory feel, rather than some super uprated clutch that costs 500quid, is made from all sorts of exotic materials and works like a switch.
    The DMF was my big concern, they dont last forever and i didnt want to fit a new clutch to a knackered flywheel. Replacing it with another DMF just wasnt happening, and if your replacing it you may as well go to 240mm.
    Aug 2010
    3,135
    As Aragorn says really !!
    Which ever route you decide to go make sure you ditch the dual mass flywheel as it's really just another component that can go faulty compared to a solid one don't think I've every heard or seen one go faulty.
    Aug 2009
    464
    So rs4 or s2 clutch and either a 1z fly or an upgrade 240 mm fly will
    Both need machining as I'd rather just buy something that bolts straight on
    Aug 2009
    464
    Aug 2010
    3,135
    Yes or you could use this and one of the 2 flywheels posted previously may be cheaper by couple of hundred quid !!
    110756040178
    Should have my clutch setup by Friday then it will be going to local engineers for machining very soon ,he quoted £80 but I like to haggle so will see lol
    Aug 2009
    464
    Quote Originally Posted by Bradderz_1988 View Post
    110756040178
    What sort of power will
    Your setup be good for
    Jul 2007
    London
    3,235
    See Darkside Performance, they are distributers of Southbend clutches in UK and Europe, they do the new range of SILENT SMF and clutch kits which feel like stock and grip massively ! Do it well, do it once !
    FOR SALE:
    Aug 2010
    3,135
    I'd be saying around 300-350lbft.
    May 2010
    Bedford
    2,877
    1Z fly and S2 3B clutch can take around 300ft-lbs just fine. Possibly more on a petrol as that figure was coming from a diesel so would put more strain on it.
    "Stick a V8 in it!"
    15,370
    The ECS setup is bolt on and doesnt require any machining, but its obviously significantly more expensive than the DIY 1z setup.
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    This is maybe something I need to think about in the not too distant future.... Can I ask a possibly dumb question. If I go 1z flywheel (coz I can get one for nowt) and the S2 3b clutch kit what needs machining ??
    2000 1.8t quattro Sport totally standard (ish)
    Aug 2009
    464
    Ecs fly is about £220 and I can get a clutch from my mate at gsf, just need to get flywheel sent to relative in Washington and wait for her to come over and put it in her bag
    Aug 2010
    3,135
    Ninenails :- have a read through this Audi 80 Flywheel, Audi S2 Clutch conversion. The beginnings...
    Basically just the hole spacing and dowels if a new fly if used it will need a skim.
  1. New clutch advice - S3
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th August 2011, 21:45
  2. Clutch advice please
    By S4DJB in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th May 2011, 18:06
  3. advice on a clutch
    By bansheeboyo in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st July 2010, 14:38
  4. S3 clutch slipping !! Advice please...
    By CJ3BLUE in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st December 2009, 16:39
  5. Clutch Advice
    By Good 2 B A Gooner in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd November 2009, 20:14
