Volks AutosEM Tuning
Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By CraigG
Thread: Alarm keeps going off!?
    Mar 2010
    Braintree Essex
    59
    A4 1.9 tdi 1999
    Since I've had the car (3 weeks) whenever I lock the car wether I do it by the button or by the key the alarm doesn't shut up! It doesn't go off straight away, for example last night I got home at 10pm, locked the car by the button. By midnight it was going off!
    I had noticed the wires that go to the squishy bonnet sensor thingy lol (please excuse my fantastic descriptions) had come off, so I put new connectors on the ends of those wires and plugged them back in. Still no difference. I haven't got anything loose or hanging inside the car.
    Any ideas guys?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    Vagcom scan to find out whats triggering it.
    It could be a failing siren.
    TD5 Land Rover Defender build
    Mar 2010
    Braintree Essex
    59
    My friend has got a diagnosticp machine from snap on, wil that scan it? If not how much is vagcom and where to get it? Thanks very much
    "Stick a V8 in it!"
    15,370
    No idea if the snapon tool will connect to the appropriate controller.
    You can buy a vagcom cable off ebay for a tenner and use the free-ware version of the software to get you started.
    Mar 2010
    Braintree Essex
    59
    Ah lovely, dont suppose you have a link for a the right one?
    Thanks for your help mate
    Mar 2010
    Braintree Essex
    59
    Right, got hold of a vagcom lead and software. Ive plugged it in and scanned the car and its showing fault - alarm triggered terminal 15.
    What and where is terminal 15? Bonnet sensor? Door sensor?
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,641
    T15 is the ignition feed IIRC... could have a duff ignition switch. if the alarm is armed and it detects a "key on" event, the alarm will trigger.
    Currently rolling in a SKODA!!!
    "Stick a V8 in it!"
    15,370
    You'll really need to clear the codes, and wait for the alarm to trigger again.
    That T15 code could be ancient.
    Mar 2010
    Braintree Essex
    59
    Codes have been cleared, alarm has triggered again and its brought up interior monitoring sensor this time. Apparently according to an Audi specialist there is a sensor in the headlining. Remove interior light to reveal it? That sound right?
    "Stick a V8 in it!"
    15,370
    Nope, interior monitoring is in the tops of the B pillars, two ultrasonic things each side.
    If you press the button on the B pillar when you get out, it should disable the interior monitoring. If that doesnt work its presumably a fault with the interior monitoring control box, rather than the sensors.
    Mar 2010
    Braintree Essex
    59
    Yep, still goes off if i press the button on the b pillar. Where is the monitering box located?
    CraigG's Avatar
    May 2008
    188
    under the rear seat, right in the middle, red plug iirc.
    I guess you could try just completely unplugging that control box and see what happens?
    tara_nta likes this.
    Imola S4 - Bilstein B6 + Eibach Prokit, Anthracite BBS Pescara 18x7.5"
    Mar 2010
    Braintree Essex
    59
    Craig. . . . . Thankyou, i wil investigate! Fingers crossed i can simply unplug it and leave it at that.
    Mar 2010
    Braintree Essex
    59
    Thanks for your help fellas. . . . . I unplugged the monitering box and the alarm has kept itself quiet!
    jcb
    Sep 2005
    uk
    4,077
    my money is on the alarm siren battery.
    it drops dead around the 10 year mark and fritzes everything
    I had all those codes and it was the battery unit causing it
  1. Ok help regarding alarm
    By Kitchy in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th December 2009, 12:43
  2. Alarm going off
    Last Post: 26th December 2009, 16:38
  3. Alarm going off, i thought it was my smoke alarm!
    By S3-Oski in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th May 2009, 18:48
  4. Alarm new
    By S3mad in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th February 2009, 17:17
  5. A3 Alarm
    By Wai-Fan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th August 2008, 01:31
