I have an A4/S4 B5 December 1999 1.8T Quattro Sport, passenger heated mirror works fine as does rear window heater, drivers door mirror has not worked for 4 years since I have had the car - only just realised they were heated ! Had the glass out and checked with a multimeter and it shows continuity on the glass element, swapped it with a new glass and same problem still does not work, I am wondering if it has been enabled? Maybe I need to think about getting hold of a VCDS diagnostic - I would like to know what you can do with a VCDS? I have read some forums on here that you can check, enable and disable modules, fault codes etc, would it be to my future advantage to buy one if anyone knows prices and where to obtain one from. I already have a basic fault code reader but is very limited as to what it can do.
Thanks.
Thanks.
