AH FabricationsVolks Autos
Results 1 to 7 of 7
    Nov 2011
    25
    Adding remote locking & coding keys
    Hi guys,
    I've got a '96 TDI 110 and am wanting to add remote locking to it. I've used the universal rclick kits before, but was wondering if there was a more OEM way of doing it on the B5?
    Also, I've only got one key at the minute. Is it possible to code a new key into the system using VCDS? If so, where can I get a blank transponder from?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    you need vagtacho to code in the key.
    As for OEM methods, it depends on the central locking pump. If you currently have a "two hose" pump, then you can swap it for a remote capable unit and it should more or less just work.
    If its the older single hose pump however the wirings different and you'd need to rewire half the car. I had a November '96 1.8T and it had the early pump, so your probably SOL.
    TD5 Land Rover Defender build
    Nov 2011
    25
    Ah ok, thanks for the info. I have got the earlier pump so I'm out of luck there!
    If I got myself vag tacho, would I need to find a blank transponder or could I program another transponder into the system?
    I've got a few Polo 6N keys + transponders hanging around from a car I scrapped last year. I'm going to take my key apart and see if they are the same. Failing that, any ideas where I could buy a transponder from?
    Cheers!
    Nov 2011
    25
    This might have just become very straight forward. I took my key apart and I don't seem to have a transponder at all? Were the early '96 models really this basic in terms of security? I've got a couple of spare flip keys and HAA blanks, so I should just be able to get my current key copied.
    Here's a picture of the inside of my key:
    Nov 2011
    25
    I've just opened my key up, and it seems there's no transponder in it. Were the early '96 models this basic in security? Here's a picture of my key innards:
    Nov 2010
    Scarborough
    103
    I think the transponder is the item bottom right in your picture.My '96 has a transponder/imobiliser as the yellow key simbol illuminates when you turn the ignition on and my key looks the same as yours.
    96 A4 Avant 1.8T sport
    Things to do:
    Sell it :-(
    Nov 2011
    25
    You were right Mike, cheers for the heads up. I've got the Megamos system on there.
    I bought myself a copy of vag tacho and the cable, and have now got my 4 digit SKC code. I've got a full licensed version of VCDS and know I can use this to code in a new key. Is it now just a case of buying a new key with blank transponder and coding it in using VCDS?
    Thanks for any help/info!
  1. Yeah I know keys again 2 button remote 3 button remote
    By cabriolet in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th December 2009, 11:15
  2. remote keys
    By 205man in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th March 2007, 13:22
  3. Remote Central Locking/Alarm Fob Battery Replaced & Now Not Working
    By steve5s in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th November 2006, 16:52
  4. eBay remote Keys - Any good?
    By imported_bearboy in forum Detailing
    Last Post: 7th April 2005, 23:03
  5. remote keys
    By s3tle in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2004, 08:05
Tags for this Thread
