AH FabricationsSky Insurance
    Biodiesel Purrrr
    Jun 2011
    London
    150
    what is 50A fuse next to ECU?
    further to this post about poor cold-starting
    TDi (not so cold) starting problems...
    I was checking connections and wiring...
    Looking inside the ECU box there are 3 relays and 4 fuses - 2 of them mega-fuses, 50A and 80A
    Anyone know what the 50A fuse is linked to?
    the 50A fuse was not blown but the plastic and the fuse and holder was slightly melted in some areas
    I have cleaned the contacts, used semiconductor paste and replaced with new fuse...
    will be keeping an eye on the new one to see if it overheats too -
    I'm hoping the melting was caused by a poor contact or badly made fuse?
    P)
    TDi Biodiesel sippin' A4 Avant - EGR blanked
    "Cars are good but Jeremy Clarkson is a dick."
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    As far as i can see, the 80A fuse is for the glow plugs, and the 50A one and the 25A one next to it is for some sort of electric coolant heater?
    TD5 Land Rover Defender build
    Biodiesel Purrrr
    Jun 2011
    London
    150
    thanks,
    electric coolant heater? how odd...
    was hoping it was something to do with glowplugs
    but 80A fuse seems fine
    back to head-scratching...
    P)
    Biodiesel Purrrr
    Jun 2011
    London
    150
    UPDATE:
    the odd thing is - when I replaced this fuse with a new one and cleaned + silicon semiconductor pasted the contacts...
    the car starts fine, and sounds smoother whilst engine is cold!
    less vibration or run-on when turning the ignition off too.
    I did also put silicon semiconductor paste onto the contacts of the relays in the ECU box,
    but all seems ok for the last few days
    worth checking if you have starting issues on a TDi AFN I'd say...
  1. Gearbox ECUs by ECU Testing.com
    By FuAudi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th January 2012, 19:57
  2. Help Please: Abs Ecu Coding and help with ecu.
    By asasprey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th August 2011, 18:02
  3. ECU problems - attempting to match Immobiliser with ECU....and failing
    By stefanhenchoz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th April 2010, 18:44
  4. Access-A-Fuse - fuse tap
    By alexkoon in forum In-Car Entertainment
    Last Post: 17th January 2005, 10:16
  5. Anybody know which fuse powers the ECU?
    By Ess_Three in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2004, 14:04
