EM TuningChris Nott
    Nov 2011
    HELP PLZ 2.4 v6 irratic idle / misfire
    hi guys, getting hairless now with this. have a problem with my v6. Had apparent misfire when idling and acccelerating. Scaned for faults but none showed up. Replaced coil pack , plugs and leads. no change. Just replaced coolant sensor yesterday and the problem seems worse, idle is going up and down from 100 to 600. Checked all my vaccum pipes and all are ok. The car judders when accelerating in high gear occasionally hear a popping noise from the engine like an internal misfire. Exhaust seems pretty smelly as well. was going to replace my throttle body but thought id just ask on the forum first. Any thoughts plz. Desperate here. aLSO CAN FEEL THE ACCELERATOR PEDAL TWITCHING ON ITS OWN.
    Jan 2011
    northants
    165
    i would try cleaning and resetting throttle body first
    Nov 2011
    i have cleaned it but how do you reset the throttle body. thx
    Jun 2011
    Great Melton Norfolk
    1,340
    you need VCDS to perform throttle body adaptation.
    Have you checked MAF sensor?
  1. a3 2.0 tdi slight misfire at idle ??
    By westu_123 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th August 2010, 11:28
  2. Lumpy idle/small misfire on stage 2+ S3, please help?
    By jamieswales in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th May 2010, 08:23
  3. A3 1.8T ** Irratic Idle** ? ? t
    By IndieA31.8T in forum General Technical / How To
    Last Post: 19th April 2007, 21:01
  4. Irratic Idle - MAP sensor?
    By StanboA3 in forum Tuning
    Last Post: 31st August 2005, 20:40
  5. help: irratic idle
    By in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2004, 21:02
