EM TuningSky Insurance
    Mar 2010
    Braintree Essex
    59
    more boost? more diesel?
    Is it possible to turn the diesel up manually? Was also thinking about putting a manual boost controller in there for a couple more psi, worth doing? What boost does/should it run standard?
    Car is a 1999 a4 1.9 tdi 5 speed manual.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,883
    Psi tuning box or remap !
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,943
    larger nozzles will add more derv and give you more power without doing anything else.
    You cant use an MBC on a VGT turbo, if you want more boost you'll need to remap the ECU
    TD5 Land Rover Defender build
    Jul 2007
    London
    3,090
    Yeah, big nozzles can be turned down but still deliver large amounts of fuel and still be future proof so you buy right, once ! 0.216 nozzles will fuel up to 170Bhp on the stock 10mm pump with a pd130 turbo and remap. I have 11mm pump, large Bosio race 520 nozzles, bv43 turbo (gtb2260Vk on stand by!) and i am still running the stock 90 Bhp tune (!) without that much smoke but i had to do the hammer mod to tame it down at WOT. As soon as the new Southbend clutch is in i can turn the boost up with a custom remap and i hope i'll breach 220 bhp. Choose your mods carefully and you'll have no problem getting the power, you'll however have trouble putting all that torque on the tarmac !
    FOR SALE:
    diffas's Avatar
    Lahti, Finland
    131
    Add diffas on Facebook Visit diffas's Youtube Channel
    You can digitally bleed and get higher boost replacing stock 2.5bar map with 3bar map. And more fuel with every-mod - some call it psi-box. :D
    Slow and smoking - A4 2.5TDi+ 220+kw
  1. Fuelsave (regular) diesel vs v-power diesel
    By pod_4 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th September 2011, 17:27
  2. Replies: 0
    Last Post: 17th January 2011, 21:00
  3. 10k boost diesel
    By rickyquicky in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st October 2010, 17:45
  4. Boost Issue - Boost Pressure Regulation: Control Range Not Reached
    By RobinA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th June 2010, 16:30
  5. Anyone fitted/know how to fit a Boost guage on a diesel?
    By evomaster3000 in forum Diesel forum
    Last Post: 27th January 2005, 18:13
