EM TuningAH Fabrications
Results 1 to 13 of 13
    Mar 2011
    suffolk
    249
    using bigger cv joint
    just a quick question some of you may know
    im nearly finished doing the s4 brake upgrade on my 1.8t fwd, now because im using the b6 uprights which have the bigger cv joint i was wondering if its going to cause havoc with the abs sensor ( bigger cv joint = different abs ring)#
    anyone know if there will be a problem??
    thanks
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,357
    they wont cause havoc with the ABS, but i doubt you'd be able to mount them to the gearbox.
    I have a TQS and have b7 ally uprights. The TQS has 82mm CVs as standard and 100mm inner, you have 70 odd mm outers and 108mm inners. When i changed to the 6 speed in my last car i used the matching shafts for the box and uprights
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,909
    Use V6 FWD shafts. They have 108mm inners and 82mm outers.
    TD5 Land Rover Defender build
    jcb
    Sep 2005
    uk
    4,070
    i just put the bigger CV's on the existing shafts.
    the reductor ring matches the upright not the sensor.
    all the sensor is doing is watching something go round and round, not how big it is
    "Stick a V8 in it!"
    14,909
    The large CV's dont fit the small shafts, from what i can see the washers, shims and snap rings are completely different sizes too.
    I've no idea how you managed it, as your car should have had the large CV's from the factory, so theres clearly something peculiar about your car that shouldnt be applied here.
    ETKA seems to suggest that some V6 FWD boxes actually have 130mm flanges, so you may want to measure them before you buy. I'm pretty certain the V6 FWD box i broke for parts had 108mm flanges.
    Mar 2011
    suffolk
    249
    right the v6 ones are all coming up 130mm flange?? i need help how did you did this jcb??
    jcb
    Sep 2005
    uk
    4,070
    ha, not sure myself now!
    wil lhave to have a look as I have some CV boots to do this week
    Mar 2011
    suffolk
    249
    i think ive sussed it ive ordered the 1.8t quattro joints they seem to be 33mm shaft which is good and they use big cv joint so the outer joint should just go on shaft or at least i hope :S ill let everyone tomorrow
    "Stick a V8 in it!"
    14,909
    Whereabouts did you crossref the joints?
    Mar 2011
    suffolk
    249
    ok that didnt work ive just red on the srs forum that i can use rs4 shafts ?? set on ebay 100+ what does everyone reckon
    AUDI RS4 S4 2.7 V6 BI TURBO B5 FRONT DRIVESHAFTS DRIVE SHAFT COMPLETE | eBayde
    finetly 108 and should have bigger cv joints?? any one check this for me?
    "Stick a V8 in it!"
    14,909
    S4 and RS4's have 108mm inners and big outers, HOWEVER, it uses a different gearbox, namely the 01E, so the shafts are potentially going to be different lengths...
    If you can measure them, and they're the same, then yes they should work.
    If they're different you might have to change the drive flanges for 130mm versions and use V6 FWD shafts,
    "Stick a V8 in it!"
    14,909
    Just did some cross reffing.
    S4/RS4 shafts are what you need. The part number also fits 180hp FWD 1.8T's (which didnt exist in the UK, but have 108mm inners and big outers!)
    Mar 2011
    suffolk
    249
    rs4 shafts ordered should get the whole lot fitted nxt month will have to post some pics up for you all
  1. how to cv joint
    By vw754 in forum Volkswagen and other VAG
    Last Post: 12th September 2011, 21:48
  2. IS A 3.0TDI INTERCOOLER BIGGER THEN A 2.5TDI ONE AND IS THE 3.0TDI TURBO BIGGER
    By johnswales in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th January 2010, 23:40
  3. CV Joint
    By Trick in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st September 2009, 06:38
  4. cv joint
    By bigblokey0 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 20th February 2009, 13:16
  5. CV Joint
    By juntz in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2008, 13:14
